It is currently Wed Aug 13, 2025 3:09 pm
PostPosted: Fri Jul 13, 2007 1:29 pm
I wish to order some of these from here (item number 14 - 7045) http://www.scparts.co.uk/index/lang-2/lkz-195/markenid-4/katnr-45/kat_sprache-2/hrubnr-1238/rubrik-3452/index.php?tpl=clickable_vertikal.tpl&artikeldetailtop=-500
It's the only place I've seen them listed - they are 53GBP about $1.50 each. It's the only thing I need from this mob at the moment so don't want to order just these - anyone else would like a set to build the order up and share the post?
David L
PostPosted: Fri Jul 13, 2007 2:15 pm
surely you could just get a circular piece of plastic from australia?
PostPosted: Fri Jul 13, 2007 2:23 pm
Or find a good second hand, should be lots of MK1 speedo binicles around, or do as cush said, make something or find something suitable, maybe from a small clock?
PostPosted: Fri Jul 13, 2007 2:25 pm
bugger that... just stretch some cling wrap over it... :)
PostPosted: Fri Jul 13, 2007 2:48 pm
you'll need a rubber band to fix it down though :lol:
78 Leyland Mini - Prince
PostPosted: Fri Jul 13, 2007 3:25 pm
i might have some spare glass for a speedo laying around, pm me if you want one
PostPosted: Fri Jul 13, 2007 5:54 pm
"Yes you can, but don't call me shirley..."
PostPosted: Fri Jul 13, 2007 6:25 pm
I think Wombat is after the little window on the side of the binnacle and not the glass in front of the speedo.
PostPosted: Fri Jul 13, 2007 7:02 pm
Morris 1100 is right - it's the two little plastic blanking piece either side of the binnacle that light up the parcel shelf when the lights are on. I have two but after 40 years they have turned yellow and brittle as plastic does and have cracks.
David L
PostPosted: Fri Jul 13, 2007 7:19 pm
I have 2 of them. A little yellow but i just put a little torch behind them and u can't really tell... No cracks, and still flexible enough.
Yours if u want them, I have an oval binnacle now.
Carl
PostPosted: Fri Jul 13, 2007 7:25 pm
PM sent
David L
PostPosted: Fri Jul 13, 2007 7:31 pm
meh.. wasn't worth it :P
but thanks anyway stephen
:lol:
Users browsing this forum: Bing [Bot] and 343 guests
