It is currently Fri Jun 27, 2025 1:00 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 12, 2007 10:47 pm
Mini Mad also has the LEd on the Rear also....not that anyone has had to see them for a while...maybe 3 more weeks
As I'm out on the road every day..At least once aweek I have to get out of my car and telling someone...that their tail lights arn't working...pleae check this weekend that all your tail lights are working this weekend before someone runs up your arse and your at fault :wink:
PostPosted: Thu Jul 12, 2007 11:30 pm
1071 wrote:
LEDs are actually brighter but the light doesn'r spread. this means that the apparent brightness changes dramatically depending on the angle you view them from
Agree, but most people when behind u, are directly behind & thats where these leds look brightest :wink:
As far as the site says they dont work with 2 screw, but u could probably sort something out.
Carl
PostPosted: Fri Jul 13, 2007 8:20 am
If anyone does buy a set of the MiniMania LED lights please PM BEFORE you instal them - I have an idea............. :wink:
David L
 Post subject: Brake
PostPosted: Fri Jul 13, 2007 5:57 pm
I run a set of leds in my clubby tailights, and they are very bright day and night.
Steve
Classic Not Plastic
PostPosted: Fri Jul 13, 2007 6:45 pm
I also have an idea. I can get hold of stuffed truck LED lights that usually have a busted lens or corroded electronics. Can we do a deal?
PostPosted: Fri Jul 13, 2007 7:04 pm
David L
PostPosted: Fri Jul 13, 2007 10:32 pm
Asphalt wrote:
Original Partnumber for peadal-mounted brakelight-swicht is 13H3735
(BMK1903A for lock nut)
Fantastic, I've got a new switch in mine but no nut. Tis held in with Cable ties at the moment.
I'll get me one of these nuts now I have the number.
Cheers.
Dicko.
