It is currently Tue Aug 05, 2025 10:00 am
 Post subject: Tail/brake lights
PostPosted: Sat Jul 14, 2007 11:48 am
Does anyone know the ratio of brighness level between the tail lights and brake lights? - I realise I could just go by the wattage but I'm sure I saw somewhere each is designated by a level of 'brighness' - also do indicators have a 'standard' brighness?
David L
PostPosted: Sat Jul 14, 2007 4:46 pm
"level of 'brighness' - also do indicators have a 'standard' brighness"
Dunno about the level of brighness of hand but maybe Queensland Transport could help with the official level of illumination. Check them out Dave.
PostPosted: Sat Jul 14, 2007 5:02 pm
Have recently been chasing up same sort of info regarding Reversing lights.
Unfortunately watts to brightness is not possible as they are different scales of measurement. ( And the ADR regs quote lumens (?) not watts.... yet to see a bulb advertising other than watts )
However as a rule of thumb I got this info from a Bulb catalogue:
Watts vs. Candle Power As a guide, the following comparisons can be
made between these 2 measurements of power or brightness:
2w = 3cp
6w = 6cp
10w = 15cp
16w = 21cp
25w = 32cp
35w = 50cp
If you have a look at the Narva web sie they have a list of ADR compliant lights - and you could look up specs of appropriate fitting...
http://www.narva.com.au/ADR_Listing_1.html
