It is currently Mon Aug 04, 2025 12:45 pm
 Post subject: Head question
PostPosted: Sun Jul 15, 2007 10:30 am
I've just picked up an 295 head to put on the 1100 block.Its been shaved but how do I tell by how much ?
PostPosted: Sun Jul 15, 2007 10:49 am
Measure thickness, was approx 2.750" when new. :wink:
 Post subject: Shaving a head.
PostPosted: Sun Jul 15, 2007 7:51 pm
Also might be an idea to measure the CC of the chambers and work out the proper size to suit the compression ratio you need to run your motor at. No point in bolting a head on an engine without working out the compression ratio.
"Let us remove your "SHORTS"
PostPosted: Sun Jul 15, 2007 8:38 pm
And if it's had more than about .075" off, it'll be more prone to blowing head gaskets.
Smallbore heads were not real thick in the deck. Their old age now and resulting internal corrosion don't help.
