It is currently Sun Aug 03, 2025 9:57 pm
 Post subject: NGK spark plug drama's
PostPosted: Sat Jul 21, 2007 5:58 pm
High heel ninja
Is any body else having a bad run with NGK spark plug, i bought my mini home from Hay & put it in the garage, a couple of weeks later i got it out, idles on 4 cylinders, drives on 3, pulled the plugs out, they looked good
Put stuck a new set in, runs prefectly, the plugs that came out had done 20k's max, 2nd set in a month that have gone to crap, anyone else had dramas?
Doogie
PostPosted: Sat Jul 21, 2007 6:34 pm
Online
Yep I last had a pair go bad on a run down the highway to Wakefield Pk. That was 2nd time I got some duds. Ever since, I've used Bosch W7DC. Same heat range as a BP6ES but I reckon they are a better plug. Side electrode is thicker so it doesn't sag with the heat.:wink:
<edit> For Wakefield Pk track work I bung W6DCs in. (same heat range as NGK BP7ES).8)
Last edited by drmini in aust on Sat Jul 21, 2007 6:57 pm, edited 1 time in total.
PostPosted: Sat Jul 21, 2007 6:48 pm
don't tell this in Germany, Bosch is a no-go over here :shock:
but don't ask me why i'm using Bosch without problems
Rover 214 atm ....
 Post subject: Robert Bosch Australia
PostPosted: Sat Jul 21, 2007 7:13 pm
Pssst its the Yttrium :shock: :lol:
http://www.bosch.com.au/content/language1/html/2265.htm
PostPosted: Sat Jul 21, 2007 8:27 pm
I found that over the years each plug manufacturer has a run of quality issues, maybe it's NGK's turn?
Daniel
PS - I've always used NGK on my own cars since switching from Champion in 1993 so I hope it's not a common thing :shock:
PostPosted: Sat Jul 21, 2007 8:36 pm
I've had trouble with NGK too - switched to Bosch and it runs better though i'm running NGK at the moment..
PostPosted: Sun Jul 22, 2007 12:31 am
i've had no issues with bosch, had various issues with other brands.
good better bosch.
PostPosted: Sun Jul 22, 2007 2:17 am
Hi all, yeah i had a drama with 8 ngk bp6es s/plugs from 3 different boxes(boxes of 10 s/plugs) thank goodness it was in my car and my wifes car (In my wifes mini,2 brand new s/plugs stopped operating within 10 mins of 1st ever start up of engine while running in cam etc...march. Then prior to leaving for hay on the friday arvo 1 stopped working, (all had except 1 had done less than 200 km's the other 1 had done just under 1000kms.). Just glad it didnt happen while we were on our way up friday night!). the other 5 were in my car at various times as it gets driven more often as well as in a much more "positive" fashion!! They just stop working there is nothing wrong with them on the outside (gap is ok, no cracks etc..), I just took mine back to the shop i bought them from and he swapped them over (coz ive been going there a while) for me and was going to speak to his rep/supplier about them. Never had this drama with ngk s/plugs before.
PostPosted: Sun Jul 22, 2007 2:18 am
sorry about the 2 postings must of hit the button twice or something??.....not paying attention!!
 Post subject: Bug
PostPosted: Sun Jul 22, 2007 9:20 am
Don't sweat it...theres a bug in Ausmini....especially prevalent in the intuduce yerself section. Have you searched on Hay 2007...there should be pics of yours and the pink Mini there.
PostPosted: Sun Jul 22, 2007 12:00 pm
I is a mookenik
i had a few issues with my last set of NGK's :( swapped them with some champions we had at work has done the trick till next week ill buy another set of NGK and see what happens
PostPosted: Sun Jul 22, 2007 7:28 pm
I have had nothing but dramas with NGK's. Similar stuff to what BALLISTIC said.
Running CHAMPION's in the GT and LOVE them. 8)
PostPosted: Sun Jul 22, 2007 8:21 pm
ausmini mod
ausmini mod
Interesting fella's...
Whats the 'problems' that your having?
Spark affects performance, performance affects my ego :)
Im running NGK's at the moment.
I did however modify the ends to sit better... :D
Peter.
PostPosted: Sun Jul 22, 2007 8:39 pm
I had problems with low speed traffic running and starting problems - switched to the same range bosch and this went away
PostPosted: Sun Jul 22, 2007 8:43 pm
I is a mookenik
tell us pristic how did u "modify" the plugs exactly lol, my plug problem happened in cold weather the car use to hesitate alot on take offs and on full pedal, has stoped so far i hope this next set of NGK's aint the same :(
Users browsing this forum: Barkfast, drmini in aust and 87 guests
