It is currently Wed Aug 13, 2025 5:59 am
PostPosted: Sun Nov 19, 2006 7:25 am
Daffodil 1275
Hi all, i am replacing the front wheel bearings but am unsure if both the bearings are the same? they look the same and have the same p/n, and which dust seal goes where, one has a lip on it and the other doesn't
am i right in thinking both bearings are the same and the seal with the lip goes against the cv joint at the back!!
Cheers Robbo[/url]
 Post subject: W/bearing
PostPosted: Sun Nov 19, 2006 8:15 am
GHK1018...
Yeah both bearings are the same,
Make sure the spaced sections go face to face on the inside of the hub (obviously)
Seal with lip goes on the back of the hub. (one closest to the CV)
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Sun Nov 19, 2006 8:39 am
Daffodil 1275
thanks mate
 Post subject: Re: W/bearing
PostPosted: Wed Jul 25, 2007 1:08 pm
Thank you Andrew :mrgreen:
I had mine in backwards and the wrong way around :lol: I knew something was up.... and SEARCH found me the answer :P All sorted now.
Users browsing this forum: No registered users and 276 guests
