It is currently Tue Jul 29, 2025 3:42 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jul 25, 2007 4:12 pm
Hi all,
is their a site i can go which will list the engince prefix so i know what i am looking at?
same thing with the body?
Rob
oh, and whats the main difference between a clubby and a clubby S?
PostPosted: Wed Jul 25, 2007 4:20 pm
Under technical data http://www.minis.com.au/
David L
PostPosted: Wed Jul 25, 2007 7:43 pm
It is a Leyland Mini S :wink: (the Clubman name was dropped in 72)
The S has these bits that a normal Mini does not have.
Flares.
Spacer brake drums.
Sports wheels (steelies not mags)
3 dial dash.
Chrome around door frame.
Better trim.
And that is about it! :lol:
 Post subject: cool
PostPosted: Thu Jul 26, 2007 3:32 pm
great, thanks for that, doenst sound anything major!
Appreciate your help!
PostPosted: Thu Jul 26, 2007 9:14 pm
My body is a S MkII but my engine number isn't even on that list :(
Edit:
Turns out the engine number is a Vic police overstamp, hence why it isn't on the list.
PostPosted: Thu Jul 26, 2007 9:26 pm
You would think that the d/h's compiling these so called lists would know by now that an Aussie Mk2 Cooper S is YG2S4
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Thu Jul 26, 2007 10:59 pm
That list is full of errors. :lol:
PostPosted: Fri Jul 27, 2007 6:57 pm
Exactly !!!!!!! .....just one glaring example .......
1965 Morris 850
1977 Leyland LS
PostPosted: Fri Jul 27, 2007 7:20 pm
maybe we should do a new list for Ausmini and have a corrrect one to refer to :shock:
PostPosted: Fri Jul 27, 2007 7:38 pm
Nah, it is much easier to just bag all the ones on the net.
PostPosted: Sat Jul 28, 2007 12:40 pm
On the subject of engine numbers - I have two engines both are 99H905AJH the numbers are 600ish apart. Also a block that is 100111855
What do those numbers tell us ?
David L
PostPosted: Sat Jul 28, 2007 3:45 pm
The 99H905AJH ones are both very late 998, The 1001 block is a 1098, from early Clubby body type YG2S7.
:wink:
PostPosted: Sat Jul 28, 2007 5:15 pm
So the 998 in the Moke is not original as it is rod change without the rods :? and the Moke has a hole for Moke style Magic Wand and therefore needs a remote change with the Magic Wand adaption (which I have from another idea) The other 998 came with the rod change mechanism.
Will I need a remote change box or can a remote dif housing be made to fit a rod box? (I think I know the answer :? )
Doc - anything special about the crank in the 1100 block or is it just bog standard ?
David L
PostPosted: Sat Jul 28, 2007 6:55 pm
Mokes and Minis from late 74 use a rod-change gearbox. The Mokes use short rods to leave the stick in the "Magic" position.
The rod length for a Mini is 475mm.
The rod length for a Moke is 145mm on the earlier ones and 210mm on the later ones. I don't know the date of the change.
PostPosted: Sat Jul 28, 2007 6:57 pm
AFAIK there only ever was one 1098 crank, p/no is 12G82. :wink:
