It is currently Tue Aug 19, 2025 12:58 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Jul 26, 2007 9:33 pm
Looks tops :D
I will have to pop up and have a look sometime. :wink:
Matt
PostPosted: Fri Jul 27, 2007 2:39 pm
You might want to go to the trouble of cleaning up the inner guards while they are exposed. Underneath all that rough stuff you can find all sorts of dramas. I found rust holes in mine after wire-brushing it back to bare metal - they werent visible before doing that.
Also makes it better to look at when the front flips away, having it clean and painted.....
You can see one of the holes where the spot welds are along the bottom edge, underneath a previous repair job, where the everyday tyre spray would land... And yes, I have continued doing the whole thing since taking this picture.
PostPosted: Fri Jul 27, 2007 7:16 pm
cheers guys, yeah nathan hats the plan, i will clean iy up, re seam seal all the seals tehn body shutz the inners, it kinda acts as a bit of sound deadener.
painting it the weekend after next (hopefully) woohooooo
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: No registered users and 315 guests
