It is currently Mon Aug 18, 2025 9:03 am
 Post subject: Mini K badge info
PostPosted: Wed Aug 01, 2007 8:39 pm
Hey guys I have a Mk Cooper S badge on the Mini K. I want to replace it with the orginal K badge. Do the mounting holes match? if I have to drill new holes will the old Cooper S badge mounting holes be visable if I change it?
PostPosted: Wed Aug 01, 2007 8:41 pm
the holes don't match - the cooper badge has holes out on the 'wings' which would be visible if you changed over to a K badge - if you can find one
PostPosted: Wed Aug 01, 2007 10:43 pm
just bog up the holes,sand back the patch where you puttied it,then spray over it,easy brother did it to his bonnet cant tell the difference :wink: :lol:
PostPosted: Wed Aug 01, 2007 10:45 pm
You didn't say Mk1 or 2, just MK.
If it is a Mk2, then it will fit straight away, they are the same.
PostPosted: Thu Aug 02, 2007 1:27 pm
Ooops. Mk 2 Cooper S badge hoping to replace with Mini K.
PostPosted: Thu Aug 02, 2007 3:12 pm
Yep, straight over, you won't even see the K badge outline as the oval badge will cover it up.
Users browsing this forum: Bing [Bot] and 315 guests
