It is currently Fri Aug 01, 2025 12:53 am
PostPosted: Sun Aug 12, 2007 1:47 pm
What size is it at the back out of the tank (under the car, installing a leccy pump) and what size is it under the bonnet?
PostPosted: Sun Aug 12, 2007 1:50 pm
1/4" Fuel Hose I reckon.
Matt
PostPosted: Sun Aug 12, 2007 5:37 pm
The steel pipe front to back is 1/4" OD (outside diameter).
If fitting a bigass motor and pipe dodgy I'd suggest replace with 5/16". However, my 1360 gets by with the original 1/4" line and a Facet electric pump, and it's got somewhat more than 120HP at the crank... 8) .
