It is currently Fri Jul 18, 2025 3:14 pm
PostPosted: Tue Aug 14, 2007 10:01 pm
Is there an easy way to get those bastard clips onto the back of the rear wheel cylinders? Or were they made to be a bitch? :lol:
PostPosted: Tue Aug 14, 2007 10:07 pm
There is a tool for this on Minispares site.
p/no is TOOL14. :wink:
Basically it's a bolt and threaded cone.
http://www.minispares.com/Product.aspx?pid=37917
Last edited by drmini in aust on Tue Aug 14, 2007 10:14 pm, edited 6 times in total.
Bitch.
:D
Don't look at it and think it'll slide on, best approach is top down.
Should be able to get two clips in most of the way, then use a small flat
screwdriver to lever the remainder over. Socket should finish it into the right spot.
:D
PostPosted: Tue Aug 14, 2007 10:09 pm
You've answered your own question here very eloquently.
You can try to push it on from the side (when I say push, I mean belt it with a hammer). Kind of easier to have somebody help you. One to use a pair of pliers to hold the clip against the backing plate and one to tap the clip on with a hammer.
Another option is to try and put the two side tabs in first and then use a screwdriver to leave the middle on one.
I did mine the other day and did one side each way. Either way sucks. :)
PostPosted: Tue Aug 14, 2007 10:16 pm
I know some 1 with that tool!!!
Ive used it... Makes the job as easy as pickin ur nose!!!!
PostPosted: Wed Aug 15, 2007 9:12 am
OK, I can see that pic now.
I might knock one of those up myself using a bolt, washer and the right sized socket. :D
I did one car last night via the bitch sideways approach. I'll do the other car via the bastard top down method :wink:
Cheers guys.
Users browsing this forum: No registered users and 111 guests
