It is currently Wed Jul 23, 2025 2:05 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Aug 25, 2007 9:12 pm
I have seen some bubbles comming up here and their so to is got the screw driver out
Result
Not to bad considering I have seen a lot worse.
I't looks like the PO has done some draising before they did the crap paint job.
I'm expecting this to be fixed with just some wels and rubbing back
PostPosted: Sat Aug 25, 2007 9:32 pm
Jim, cut it out until you get clean metal all round, then weld a patch in. Otherwise, it'll just keep coming back. :evil:
Trust me- I owned 2 Valiants... :lol:
PostPosted: Sat Aug 25, 2007 9:44 pm
Bugger ow well do it rite the first time :wink:
its okay I know a good welder, he does it for a job.
front drivers side seam and sills are the next place I look tomorrow..little more worried about these
PostPosted: Sat Aug 25, 2007 9:46 pm
.... and a Fiat 124 Coupe ! :lol:
Curly
PostPosted: Sat Aug 25, 2007 9:54 pm
Forgot that...
Yeah well- the 2nd one (1968 model) was pretty good, it must have had a salt spray-free trip out here. I fitted a sill, that was all. And poured about 5L of fishoil through it... :lol:
As for the 1st one (I bought new in Jan `69) it got rust under the windscreen trim within 12 months. And it just got worse from there.:cry:
PostPosted: Sat Aug 25, 2007 10:27 pm
I had bits like that in my A panel Jim.... you've seen what was lurking underneath :shock:
PostPosted: Sat Aug 25, 2007 10:32 pm
like others have said, if that rust is there... there is sure to be more behind it. check out surrounding areas, spray fish oil in there and weld it back up if the other metalwork is ok.
Shut up Simon :twisted:
PostPosted: Sat Aug 25, 2007 10:49 pm
Ohh Gaf you have opened a box of worms...you have to grind all the bubbles of and then post pcture of your holey morris....or half morris half air.. :roll:
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Sat Aug 25, 2007 10:55 pm
Yep Swiss Morris
and I'm expecting to find some more tomorrow
PostPosted: Sun Aug 26, 2007 6:54 am
Rust is heavier than metal- cut it all out and you'll go fasterrrrrrrr.. 8)
PostPosted: Sun Aug 26, 2007 7:57 am
I'm confused why you opened this can of worms a couple of days before kings school and just before Gannons?
Was it rego related?
KB
PostPosted: Sun Aug 26, 2007 8:15 am
Kings School has been and gone but Gannons is around the Corner.
The rust area's that I know of are slowley progressing and the further I look i see a few more bubb;;es as the PO didn't do the rite thing as well as doing a bad (thin) paint job. Spring is around the corner and so is Summer so its perfect time to start.
Sue will how ever will have to drive around in a patch work paint for a while as she will not allow her belovered off the road
We'll go for Rust and Dust or Encoragment at Gannons :lol:
 Post subject: Re: Morris A Panel Rust
PostPosted: Sun Aug 26, 2007 8:28 am
Result
Is that also a crack in the paint work,under the door hinge?If so that can only mean one thing..."white ants". ooh I also owned a VC Valiant a long time ago
and yes they had a few issues with rust :cry:
PostPosted: Sun Aug 26, 2007 12:44 pm
No crack thier but here is a few more shots of the PO's work
I think I now call Morris "Braisen"
Users browsing this forum: Bing [Bot] and 84 guests
