It is currently Sun Jul 27, 2025 2:54 pm
PostPosted: Thu Sep 06, 2007 6:58 pm
Hi all,
I just snapped off one of the grease nipples on my drum hub.
Does anyone know any tricks to get the broken piece out i dont really want to do another hub up again.
please any help much appreciated.....
thanks
Steve :(
Vtec Mini clubman. Commenced Jan 06.
Still Going June 07
http://s25.photobucket.com/albums/c71/sunburstvl/
PostPosted: Thu Sep 06, 2007 7:11 pm
How much of it is still showing , can you get a set of vice grips on it and wind it out ? Failing that get an easy out that will fit the hole in the middle and wind it out with that .
PostPosted: Thu Sep 06, 2007 7:16 pm
you can get a screw and bolt remover, you drill a hole in it and thread thing thing in and it should undo
PostPosted: Thu Sep 06, 2007 7:17 pm
Nah theres none of it sticking out, would i be able to get those easy outs from bunnings or something like that??
Thanks
Still Going June 07
PostPosted: Thu Sep 06, 2007 7:19 pm
Really crappy ones can be had from supercrap, but I think you will end up having to get that out as well once it snaps. Nicer ones come from tool stores or specailty nut/bolt suppliers. P&N and SUTTON make nice ones.
You might also try a sharp screw driver of the right width driven in the hole and turned counter clockwise....might save you a trip and a night...
PostPosted: Thu Sep 06, 2007 7:35 pm
A big nail might hold with help from a hammer then use vice grips on the nail
David L
PostPosted: Thu Sep 06, 2007 7:49 pm
what type of thread and size are the front grease nipples
PostPosted: Thu Sep 06, 2007 9:07 pm
use an easy out, you dont want to drill, bash etc etc because you will force crap in there. grab a cheap set they will do the job fine.
blokeinamoke wrote:
PostPosted: Thu Sep 06, 2007 11:43 pm
mini-dunger wrote:
use an easy out, you dont want to drill, bash grab a cheap set they will do the job fine.
it snapped for a reason....
i snapped an expensive easyout, in a door hinge.
engineer still cant believe i drilled it out.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Sep 07, 2007 8:38 am
quote me in entirety, otherwise my point is missed!
i was thinking that maybe it broke because it had be hit in the past and was fractured? In all seriousness there is no better way is there?
blokeinamoke wrote:
