It is currently Fri Jul 25, 2025 12:52 pm
PostPosted: Thu Sep 06, 2007 11:03 pm
Having not delved into tin master cylinders in many years, what is the difference in the internal makeup of a clutch master cylinder to a brake unit? I seem to remember one had a small one way valve in it to leave some residual pressure in the brake lines? Am I right or is my mind starting to go to mush.
PostPosted: Thu Sep 06, 2007 11:16 pm
The Forkmeister
Mick,
Give Glen, The mini king's mechanic a call tomorrow on 02 46481233 he''l be able to tell you the difference.
Gerg
May the fork be with you.
PostPosted: Thu Sep 06, 2007 11:17 pm
probably starting to go to mush, but it's still right - there is a valve in the brake one, but it's not necessary (according to Doc :D), just makes it easier to bleed them. I went through my big pile of MC's one day, and only 1 of them had the valve in it
PostPosted: Fri Sep 07, 2007 6:54 am
Thats cause the rest were Clutch MCs :roll:
David L
PostPosted: Fri Sep 07, 2007 7:24 am
Cool, I remember seeing that valve, but couldn't find them in mine either. So it just retards the return a tiny amount?
And bleeding is a very good reason too.
PostPosted: Fri Sep 07, 2007 3:36 pm
This space for rent
Is there a difference between MCs for disc braked cars vs. drums, aside from the reservoir size?
I seem to remember reading somewhere about the one-way valve in the drum MC needing to be removed when converting to discs, otherwise the caliper pistons don't retract.
PostPosted: Fri Sep 07, 2007 4:16 pm
I've seen that on other drum conversions where there is a valve to keep a residual pressure in the lines for non-self generating drums.
But as for minis, I dunno..
PostPosted: Fri Sep 07, 2007 4:18 pm
:P
