It is currently Mon Jun 30, 2025 8:14 am
Post new topic Reply to topic  [ 154 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
PostPosted: Mon Sep 10, 2007 12:14 pm
Wilwood upgrade on a European Astra.....
PostPosted: Mon Sep 10, 2007 12:18 pm
JC wrote:
Well there you go, there's more than one way to skin a cat.
Yer about 3..but why are we talking about that :shock:
PostPosted: Mon Sep 10, 2007 12:29 pm
Which is opposite to Tony's?
PostPosted: Mon Sep 10, 2007 1:08 pm
Err no!!!
Its front wheel drive.
That is a pic of the passenger side, the engine is in front of the caliper (i.e. its a leading caliper, like the Mini). Have a look, you can see the driveshaft and the gearbox casing.
Therefore direction of rotation as you are looking at it is counter-clockwise!
So therefore, exactly like Tony's, and that pic of the Lambo!
PostPosted: Mon Sep 10, 2007 2:46 pm
So it is! I should know by now not to argue, but its bred into me.
PostPosted: Mon Sep 10, 2007 2:49 pm
But if you dont challenge things, how will you ever learn?
:wink:
PostPosted: Mon Sep 10, 2007 6:48 pm
Barbie came home on Saturday for a brief spell, so we could do some more work on her.
Still to be done is the alternator, gear shift linkages, gear shifter mount, and guard cutting for the 13 x 7's. As well is the electrical etc, but this will be outsourced to an auto electrician. So, still a fair bit of work, but not daunting.
I dropped into the fabricators today, to see whether they had finished the dump pipe for Barbie. Its mostly done, with just one more 45 degree bend to go on, the mounting flange and the wastegate pipe - should be fully completed by Thursday or Friday.
Some pics.........
Tricky
PostPosted: Mon Sep 10, 2007 7:20 pm
Mini Mad wrote:
Correct way for the TAROX brakes:
Q. Which way should the grooves face on a grooved/grooved & drilled disc?
A: In the case of the G88 and Sport Japan discs the grooves should radiate outwards towards the rear of the car. A C83 disc should run in the opposite direction.
G88 Orientation
Sport Japan Orientation
Thanks for that Josh... That is the way i had put them on but just wasnt sure
Life's a garden.... Dig It!
PostPosted: Mon Sep 10, 2007 8:45 pm
Thats gonna be a real nice dump pipe there. Similar to what I have in mind.
Are you going to try to extend a divider into the turbo side of the flange for better flow?
Some examples below.
Neat and not too hard to do.
Right most option best of these obviously.
Madmorrie
PostPosted: Tue Sep 11, 2007 10:38 am
Just a quick one, what are you making your dump pipe from, just exhaust tube?
PostPosted: Tue Sep 11, 2007 12:27 pm
Hi Morrie,
Thanks. The wastegate pipe will join up with the dump pipe proper just before the next 45 degree bend is welded on, so at the very end of the large pipe as you see it. They say try and make the wastegate pipe about 18 inches long before joining into the main exhaust stream.
Miniboy - the exhaust is made out of mild steel tubing, mandrel bent. Its the standard pipe that exhaust shops would use.
PostPosted: Thu Nov 15, 2007 9:00 am
Well, two months have passed and this thing needs to be finished by Christmas. Any progress to report Lord Treloar?
PostPosted: Thu Nov 15, 2007 9:01 am
Well, two months have passed and this thing needs to be finished by Christmas. Any progress to report Lord Mayor Treloar?
PostPosted: Thu Nov 15, 2007 1:01 pm
Hi JC,
Well at the moment, this is where Tony (and Barbie) stand:
1. Subframe - check
2. Alternator mounts - to be done
3. Shifter mechanism - to be done
4. Shifter linkages - to be done
5. Electrical - to be done
6. Cooling - to be done
7. Brakes - check
8. Wheels and Tyres - check
9. Body - check
10. Interior - check
11. FMIC - check
12. FMIC mounts - to be done
13. Instruments and dash - check
14. Seat mounts - check
15. Fuel system - to be done
16. Dump Pipe - check
17. Exhaust System - to be done
18. Engineer sign-off - to be done
19. Rego - to be done
Thats about it (a few minor things left off the list like throttle cable) but that's the bulk of it.
Tony needs to pull his finger out eh?
Tricky
PostPosted: Thu Nov 15, 2007 2:57 pm
Thats one reason why i dont have a list except for the one in my head of things to do... Just looking at a list with so many things to do gets depressing
