It is currently Tue Aug 12, 2025 10:36 am
PostPosted: Mon Sep 10, 2007 3:30 pm
Ok, are there two sizes of knuckle joints? i just bought 4 from the uk, and the end that goes into my hilo's is small, and loose in the hilo, this cannot be good! :?
PostPosted: Mon Sep 10, 2007 4:17 pm
It's not meant to go into the hilo, it's menat to go into a bolt that sits in the hilo, or a rear hydro rod for the rear. is this the problem?
cos as far as I know they only changed a little later on, and not to do with the diameter of the peg, only the height?? Am I right?
PostPosted: Mon Sep 10, 2007 4:21 pm
:lol: id have to shoot myself if i ade that mistake 8)
the peg is very loose in the proper hilo tube(adjusta rides), or the bolt, which is odd, as both are from the same supplier, they are not cheep ones either.
PostPosted: Mon Sep 10, 2007 4:24 pm
Their is actualy two sizes..I also have the same problem..yep their is a nut on the end which the Knuckle or Rod (for the Rear) goes into.
Its a Brand that is slightley differant..I also Purchased the same one's..I'll get a pic when I can as I can't remember what company I purchased them off.
PostPosted: Mon Sep 10, 2007 4:26 pm
mine are from minisport UK (mod can remove if inappropriate)
PostPosted: Mon Sep 10, 2007 5:48 pm
there are two sizes, yes. the ones fitted to Minis with a shaft diameter of 1/2", will fit original Hilos, too.
and there are the ones with 14mm shaft, fited to Metros i've been told, also used with MiniSport Adjustarides
Rover 214 atm ....
PostPosted: Mon Sep 10, 2007 5:51 pm
ah ha, yes thats about the same size difference i have, hmmmm, i think ill get some brass bushes made up, as the old ones never seem to come out of the adjustaride anyway!
PostPosted: Mon Sep 10, 2007 6:22 pm
Mine is closer to 13mm :lol:
PostPosted: Mon Sep 10, 2007 6:30 pm
you may be able to get the brass you need from a hobby shop. They have brass tube of a particular ID that will slip over the knuckle to make another OD.
They make the brass tube particularly so it has an OD that will slide into the next ID. just gotta hope it can be bought iin that larger size (which I think it can)
PostPosted: Mon Sep 10, 2007 6:33 pm
cool :D off to the bobby shop with an adjustaride and a knuckle joint 8)
Users browsing this forum: No registered users and 205 guests
