It is currently Sat Aug 02, 2025 1:08 pm
 Post subject: Fixing flares.
PostPosted: Tue Sep 11, 2007 6:10 pm
okay well upon my stupidity and organisation skills...i have broken a flare that i bought just recently, it is a clubman s flare bought from the mini place in padstow, anyone else done this and fixed it? or should i just buy another one?
I have a problem.. apparently
PostPosted: Tue Sep 11, 2007 6:13 pm
You'll probably find they only come in sets, unless it's a front left, or rear right. They would be very hard to fix I imagine, as they're injection moulded plastic (I think) so they wouldn't be as easy to fix as fibreglass. They're very thin too.
PostPosted: Tue Sep 11, 2007 6:16 pm
bugger :( although it is a rear right... might try some superglue or model glue becuase that stuff melts the plastic as it sticks it....
PostPosted: Tue Sep 11, 2007 9:34 pm
try that, and use some filler or fibreglass or something to smooth it off. sand it back a bit maybe.
you want plastic "cement" (i think it might be called "polystyrene cement?) if you want to melt it a little to weld it together
is it painted?
78 Leyland Mini - Prince
PostPosted: Tue Sep 11, 2007 9:37 pm
only primed then a roll of vinyl found it.. :(
PostPosted: Tue Sep 11, 2007 9:42 pm
better than having to much around matching paint!!!
you've crossed the first hurdle :D
PostPosted: Tue Sep 11, 2007 9:49 pm
I Don;t think the Modeling Glue will do it enough. Some of the modls I have done from Years ago (yer I know It has been some time) but they have come apart..it Give the Super Glue ago or the Loctite Super Glue I have seen Advertised of Late of Tv
PostPosted: Tue Sep 11, 2007 9:54 pm
ill flog some from work :D
PostPosted: Wed Sep 12, 2007 3:04 pm
one of my flares was broken into four pieces. I did a decent job of fibre glassing it back together (not perfect by a long shot, but could have been).
My flares were fibre glass to begin with though.
you could try taking a mould of the broken one and forming a fibre glass one. maybe just buy a new one though
PostPosted: Wed Sep 12, 2007 3:20 pm
try John at Mini King - he is close enough to you...
I only recently threw out the flares that came of my car...
PostPosted: Wed Sep 12, 2007 5:01 pm
behind my work :) i can see all his stuff out the back from my tea room lol :D ... and i like to brag about it
 Post subject: Re: Fixing flares.
PostPosted: Wed Sep 12, 2007 6:42 pm
High heel ninja
Take it to a motorcycle shop, they should be able to plastic weld it.
doogie
PostPosted: Wed Sep 12, 2007 6:43 pm
awesome!! thats what i wanted to hear! lol cheers mate!
