It is currently Mon Aug 11, 2025 5:07 am
PostPosted: Sat Sep 15, 2007 10:07 pm
I'd use the Anton (GT) method-
go to Supercrap, buy a sand blast nozzle, buy or borrow a compressor and dry sand, do it on your lawn. Hose it in when finished.:)
That sounds a lot like me! I sat a set of Clubman S rims on the lawn with a 30 dollars Supercrap sand blaster nozzle. The beach sand used is everywhere under where I was living and simply went back from whence it came as it was used.
PostPosted: Sat Sep 15, 2007 10:28 pm
The reason the use of beach sand for blasting was banned is because it contains mostly silicon dioxide & makes a lot of hazardous dust as it breaks down into fine particles and hangs in the air for you (and your neighbours & family to breathe).
Silicosis is not a nice way to die. Proper blasting sand (zircon or similar) is cheap. I use a Supercrap sandblaster at home too, but would never stoop to using beach sand after seeing the effects.
PostPosted: Sat Sep 15, 2007 10:42 pm
:( ...would you feel better if I said I was wearing a mask as well....
PostPosted: Sat Sep 15, 2007 10:47 pm
Your kid's spiderman mask doesn't count :shock:
KB :D
PostPosted: Sat Sep 15, 2007 10:55 pm
Oh no, it was the proper rubber mask with the ping pong ball in my mouth for protection!
PostPosted: Sat Sep 15, 2007 11:10 pm
Have to word this one correctly......nope I give up :lol:
PostPosted: Sun Sep 16, 2007 7:51 am
Bring out the gimp.......
PostPosted: Sun Sep 16, 2007 8:24 am
Did a certain Mr Willis give you a hand also? :lol:
PostPosted: Mon Sep 17, 2007 12:03 am
Sorry !!!! I should have clarified the use of caustic and acid on aluminium alloys. DO NOT USE either chemical.
I presumed that the rims were steel. you can mix up some caustic [you can buy it from supermarket] and immerse the whole rim in solution until paint is removed.
We use it to clean cylinder heads off marine diesel engines, it is the only chemical that removes carbon deposits from heavy fuel oil.[/img]
www.minisprintgt.com
Users browsing this forum: No registered users and 112 guests
