It is currently Fri Aug 15, 2025 12:22 am
PostPosted: Thu Sep 13, 2007 9:39 pm
Hanra wrote:
Its has nothing stamped on the boot latch, so the other place to look would be the wiper/headlight switches then? Any other locations?
Starter , generator and distributer but they are likely to be changed by now though you could be lucky . Sometimes the underside of the fusebox is dated , the lower edge of the voltage regulater should also have the date . You can work the date out from the markings on the window glass but it's a bit involved .
PostPosted: Thu Sep 13, 2007 9:41 pm
The wiper motor was made in England and spent a couple of months sitting on a boat. The date it was made is not related in any way to the date the car was made. (except that the wiper motor was made first)
There are dates on every electrical item. I look at the last date and add at least two months to get an approximate date. I don't just look a the wiper motor and say the car was made on the same day.
Looking at the cars number and knowing roughly how many were made I said the car was made in early 68, I stick by that.
PostPosted: Thu Sep 13, 2007 9:50 pm
OK, so lets go with that then.
The engine number: 99H119/H/365, the last 3 digits. Would that mean its the 365th donk built?
PostPosted: Thu Sep 13, 2007 9:54 pm
possibly but these motors are imported and fitted in random order. so maybe not.
Early matic cars had another engine prefix, 9AN/A/H, according to my (non- factory) book.
PostPosted: Mon Sep 17, 2007 3:49 pm
Hanra wrote:
Monte wrote:
you tight bastard support the local little fella
P*ss off!!! Ive never even see the Mini Experience for sale in any Cairns Newsagents.
Subscribe to him its not rocket science
A good point and good check is also a few other parts that may not be changed, dipper switch on floor, steering rack and also look at ignition key, hoen centre many more other points to look at
But I spose you know that
Monte
Users browsing this forum: Bing [Bot] and 221 guests
