Mort Subite wrote:
Hydros are not like a hydraulic cylinder.
Hydro displacers are actually a rubber cone, with a hydo `bladder' and valving inside. As such, if you block the fluid flow front to rear, or separate them as Mishy has, they still act somewhat as a rubber cone.
You can watch this effect if you bounce on the front of the car, the hoses flex as the top of the displacer moves up and down.
I'd agree with DrMini, I understand the BMC Hydrolastic system needing displacement - typically front to rear. A sealed unit has no such displacement, independant or not.
To my mind its like a Citroen Hydropneumatic system running on flat spheres, it defeates the intended purpose as there is no give other than the give in the rubber of the units on a Hydrolastic system, or the flow of high pressure fluid from within the Hydrpneumatic system.
One question I'm inclined to ask is "Why reinvent the wheel?"
The displacement of fluid front to rear is not your suspension, it is just there to improve the ride.
When you hit a bump with hydro you are not pushing all that fluid from the front to the rear, you are deflecting the rubber spring and pushing a little fluid to the rear.
A Citroen Hydropneumatic system with flat spheres is like hydrolastic without the rubber springs.
Removing the interconnection does not alter the spring rate, it gives better control of pitch. Good for a competition car but lousy over speed humps.
