It is currently Wed Aug 06, 2025 7:02 am
PostPosted: Fri Sep 21, 2007 10:14 am
Ok now I'm sure when you were kids you did the same thing, pegged a playing card to the fork of your pushbike and when the wheel went round the spokes hit the card and you sounded like a motorbike.
Anyway my 1993 auto Rover Mini is making that noise. When it idles at lights and especially exelarating it sounds as though someone has pegged a playing card to my wheel and I now sound like a motor bike.
Anyway have any idea what that might be? Help needed thanks.
1979 Leyland Moke (which is for sale)
PostPosted: Fri Sep 21, 2007 10:17 am
Hey,
Im no mechanic just taking a stab...
Could be sticky valves? You could try some valve stuff that helps get them lubricated (i think). Its available from places like supercheap, repco, autobarn usual car places, i think its like $10.00
Have you checked your oil as well?
Michael.
PostPosted: Fri Sep 21, 2007 10:23 am
i know its not oin the motor, but sortof in the area...wheel bearings?
78 Leyland Mini - Prince
PostPosted: Fri Sep 21, 2007 10:48 am
Exhaust leak.
PostPosted: Fri Sep 21, 2007 11:07 am
As willy said , exhaust leak , but look around the manifold gasket particularly .
PostPosted: Fri Sep 21, 2007 11:28 am
I used to use bulldog clips.
PostPosted: Fri Sep 21, 2007 11:57 am
bearing in my altinator used to tick, and when reved hard it would wine
PostPosted: Fri Sep 21, 2007 2:40 pm
Im sorry, i cant help this :D
The Mysterious Ticking Noise!
http://www.youtube.com/watch?v=Tx1XIm6q4r4
PostPosted: Fri Sep 21, 2007 3:03 pm
I'm gonna go with exhaust as well.
The two most common places are the manifold gasket and the gearbox mount. It's very easy for the manifold gasket to develop a hole especially if a couple of bolts have come a bit lose.
Where the exhaust mounts to the gearbox is also a common problem as the welds sometimes crack.
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Fri Sep 21, 2007 3:23 pm
maybe someone pegged a playing card to one of your wheels
PostPosted: Fri Sep 21, 2007 3:28 pm
Thanks for all your help. I'm taking it to Link tomorrow. See if they can fix it, seen as it does seem to be the Exhaust as I had a few guys look at it here at work.
I checked for the playing card too, and that youtube video was a pisser, very clever you ausmini people. :D :D :D
Thanks again 8)
PostPosted: Fri Sep 21, 2007 3:31 pm
[quote="-=MiniMafia=-"]Im sorry, i cant help this :D
(in best Peter Sellars [Pink Panther] voice)...........it's a bemb !
PostPosted: Fri Sep 21, 2007 4:26 pm
tappets?
PostPosted: Fri Sep 21, 2007 4:47 pm
Exhaust Leak, Large Tappet Clearance or worst cast engine bearing :shock:
PostPosted: Fri Sep 21, 2007 4:55 pm
Some left-field thoughts -
1. Check the alternator brackets (can produce a rythmic knock when really loose
2. Harmonic balancer - when the rubber perishes and wears, it can make a ticking sound that is more prominent on idle and starts to disappear as the revs get higher
KB
Users browsing this forum: No registered users and 66 guests
