It is currently Tue Aug 19, 2025 2:24 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Fri Sep 21, 2007 1:32 pm
smithy wrote:
Timbo wrote:
I have a colourtune, its fun and looks nice, but it really only helps with the mixture at idle, you can't use it under load where you really need to get the mixture spot on. It won't help you much if you haven't got the correct needle to begin with.
Not quite right. It can be done under load. Vizard and at least one or two other people has written how to do it. (Got the articles somewhere) Without the all the details and safety aspects and driveshaft angles, etc, the very, very bottom line is jack the front of the car up, start it running then use the brakes to put it under load while pushing down on the accelerator to keep it from stalling. Done it a long time ago more than once. It works.
There's the other "under load" test where all you (very basically) need is a pencil in the carby piston but I haven't tried it yet. Got the book, sounds a great idea, very simple and costs nothing. It shows you where to modify your needle to whatever your engine wants it to be. If the needle can be modified that far which would generally be true as your standard needle would require more enrichment that leaning out if you've modified the car. But my wife says I'm constantly wrong so don't take my word.
smithy
But Gunson say not to use it under load cos the glass will blow out and get you in the eye.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Sep 21, 2007 2:16 pm
Hi Tim,
Re your cooment "But Gunson say not to use it under load cos the glass will blow out and get you in the eye." I certainly hear you. However, in my message I did say I wasn't going into all the details including the safety aspect. For instance, making certain that the car won't fall off the axle stands and run over the person leaning over the engine looking at the Colourtune. I was just highlighting the fact that it can be done under load. I also seem to recall that Gunson recommend a limited usage time (60 seconds ???) as extended use (overheating ???) will discolour the glass or something as well.
Point is, it can be done under load.
smithy
Users browsing this forum: No registered users and 445 guests
