It is currently Wed Aug 13, 2025 9:01 am
 Post subject: clutch question
PostPosted: Fri Sep 21, 2007 3:12 pm
As i gear down and let out the clutch, im getting an awkward shudder that makes evrything vibrate. Does anyone know what is the cause of this? I appreciate any feedback
PostPosted: Fri Sep 21, 2007 8:08 pm
The drive straps on your flywheel may not be parallel to the flywheel when assembled. If so they bend when you let the clutch up on changing down, as they are then in compression (not tension) but not straight.
This allows the backplate and the diaphragm to move off centre giving you a shudder.
This misalignment is caused by people machining the faces of flywheels and backing plates with no regard for the assembled clutch height.
see http://www.minimania.com/web/DisplayID/ ... ticleV.cfm for the theory of setting a clutch up properly.
PostPosted: Fri Sep 21, 2007 11:11 pm
Broken engine mount. Broken Rubber drive unit. Or what doc said
Daniel
Users browsing this forum: No registered users and 232 guests
