It is currently Wed Aug 06, 2025 7:40 pm
 Post subject: ARP Bolt tension
PostPosted: Sat Sep 22, 2007 1:19 pm
Interesting link that cropped up on another forum http://www.aptfast.com/ARP_Additional_Stuff/ARP_notes_info/arp_t_specs.htm
David L
PostPosted: Sat Sep 22, 2007 5:28 pm
i am surprised the use of arp lube changed the settings so much.
blokeinamoke wrote:
PostPosted: Sat Sep 22, 2007 7:09 pm
The most accurate way is to use a bolt stretch gauge, if you have one (I don't).
ARP `Cooper S' bolts & nuts (3/8 UNF) are supposed to be 50lb/ft, torqued up 3 times using the ARP molylube in the bolt kit.
These ARP nuts do not have nyloc inserts- it's the `stretching' of the bolts that keeps them tight. :wink:
