It is currently Sat Jul 19, 2025 10:46 am
 Post subject: wont start no spark
PostPosted: Tue Sep 25, 2007 12:38 am
hey gang, got the loom in mad- mk1 and have had a quick play with the motor, to see if i can get it to start.
a friend that worked at a mechanic, roughky did the timing,
i have power at the coiul, but number 1 theres no spark (with the plug out, on the lead, against the block..)
now, theres a wire hanging of my dizzy.
where does this go?
i looked on the delux, and that wire returns to the coil, but in my loom, there is already wires that go to the coil.
any hints tips tricks ideas.
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Sep 25, 2007 12:43 am
That wire from the dizzy should be connected to the -ve terminal of the coil.
You will never get a spark otherwise.
Time to check what those other wires are you've hooked up to the coil :!:
The +ve terminal should have a supply from the ignition switch.
PostPosted: Tue Sep 25, 2007 12:47 am
thats wha ti thought, will try it toorrow.
on the loom , theres 2 wires, one says
+ve coil
other says -ve coil
thats on teh labels on teh wires from classic wiring looms.
hmmm :?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Sep 25, 2007 6:06 am
Follow the -ve coil wire through and see if it has a loose connector for the distributer wire .
PostPosted: Tue Sep 25, 2007 7:12 am
your loom will have power to the coil and a tacho feed, hence two wires. As said you need to connect the dissy to the coil to get power to it. :wink:
Aaron
PostPosted: Tue Sep 25, 2007 8:52 am
The coil ends up with three wires hooked to it normally
I can only please one person per day,
Today is not your day,
Tomorrow is not looking good either.
PostPosted: Tue Sep 25, 2007 9:41 am
This space for rent
.. when you have a tacho fitted. Without a tach, it's only two: +12V from the ignition switch (coil +ve) and the low tension trigger from the points (coil -ve).
PostPosted: Tue Sep 25, 2007 9:50 am
thanks heaps guys, as i suspected.
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: Bing [Bot] and 92 guests
