It is currently Sat Jul 19, 2025 1:17 pm
PostPosted: Thu Sep 27, 2007 9:51 am
As per title, do new cam bearings generally need to be reamed once fitted? I only ask as I have one new set here that slide perfectly over the cam, and another one that doesn't which is from a different manufacturer but otherwise looks the same. I'm wondering if it is supposed to be reamed or if it is a dud.
PostPosted: Thu Sep 27, 2007 11:51 am
There are two sorts on the market - 'non reamable' and 'reamable'. Apparently the non reamable can have sloppy tolerances and you run the risk of vibration moving the bearing. This happened in my engine I'm rebuilding - not with me but previous owner as when I pulled it down the centre bearing was 8mm out of the web and had fouled the push rod. The reamable one can be reamed to a tighter tolerance and you end up with a smoother running cam. A special reamer is used that lines all three up as well.
David L
PostPosted: Thu Sep 27, 2007 7:10 pm
Most cam bearings that you could buy now from Karcraft and elsewhere for years, are pre-finished.
I even had a NOS set in a BMC box that is pre-finished.
But you need to be real careful fitting them, or they distort- which is why I pay Graham Russell to fit mine, he has the proper gear. :wink:
PostPosted: Thu Sep 27, 2007 8:02 pm
By proper gear do you mean the dollies?
PostPosted: Thu Sep 27, 2007 8:05 pm
If that's what you call them, but I'd call them guide spigots and plates.. :wink:
It's easy to bruise and deform them if you try and hit them in without them being guided.
I'd make some guides up if I had a bunch of bearings to do.
PostPosted: Thu Sep 27, 2007 8:08 pm
Yep that paints a picture nicely. Thanks.
I've seen guys do it with three spigots (?) machined to fit the inner diameter of the individual bearing with a shoulder machined half way up. Then they were tapped in. Still easy to misalign I guess.
PostPosted: Thu Sep 27, 2007 8:12 pm
I would put a 16mm hole in all the spigots, then pull them in with a long piece of H/T threaded rod and nuts.. No BFH required. :wink:
PostPosted: Thu Sep 27, 2007 8:24 pm
You are right, much more elegant.
