It is currently Fri Jul 18, 2025 5:59 pm
 Post subject: 998 Cooper SU Needles
PostPosted: Sat Sep 29, 2007 11:12 am
Can someone tell me what needles the 998 Coopers came out with as standard. Just looking for a starting point.
Dicko.
PostPosted: Sat Sep 29, 2007 11:20 am
998 Cooper-
Std GY
Rich M
Weak GG
PostPosted: Sat Sep 29, 2007 11:45 am
Thanks Doc.
Gives me a starting point.
PostPosted: Sat Sep 29, 2007 11:50 am
Sorry Doc, should have asked what colour spring at the same time?
PostPosted: Sat Sep 29, 2007 3:09 pm
Blue ......
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Sep 29, 2007 7:29 pm
Thanks AJ.
PostPosted: Sat Sep 29, 2007 7:35 pm
If it helps at all I'm running a 1030cc motor with a 998 cooper head and various other good bits and I run M needles in my twin 1 1/4 SU's with no problems at all. Good torque, great revs and decent economy and responsiveness.
Hope it helps
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Sat Sep 29, 2007 7:42 pm
Thanks again.
We've got a 998 with (so we are told) mild cam, bore (not sure how much) and reco'ed head. Again its a 12G202 but don't know exactly waht has been done. There's receipts for all the work but they are as descriptive as an old cash register docket. I'll pull the head off one day and have a good look.
Anyhow I have replaced the very worn single with a set of twins off a Cooper S. Made a huge difference but the exhaust is very black so I suspect running very rich.
As I've got no response to my other thread about Dyno Tuners in the local area. I may have to choose a set of needles to try.
All of your help is muchly appreciated.
Dicko.
PostPosted: Sat Sep 29, 2007 7:46 pm
I've found if using sports filters (Ramflo etc) on a 998 or 1098 with twin HS2s, M needles generally work well. :wink:
PostPosted: Sat Sep 29, 2007 11:43 pm
d1ck0 wrote:
Thanks again.
Dicko.
As the good doc says, The M needles are going to be pretty good. Get yourself a colortune spark plug, and a workshop manal, and preferable a carb balancer, and you'll get the tuning as near perfect as possible, in a very short time
Matt
