It is currently Fri Jul 18, 2025 10:25 am
PostPosted: Sat Sep 29, 2007 8:39 am
As in the title, should there be a seal where the pinion comes through the body at the firewall? I've just gotta paint the U bolts and the rack can go in.
PostPosted: Sat Sep 29, 2007 11:22 am
Yes there's a bit of foam goes in there. I used a bit of polyurethane foam 1/4" thick, just cut it out with scissors.
PostPosted: Sat Sep 29, 2007 11:40 am
Thought thats what it might have been. Thanks Dr, as always :lol:
PostPosted: Sat Sep 29, 2007 3:55 pm
If you buy a spindle of CD's or DVD's, you get a round foam type of thing on the top of the spindle, the size of a 20c piece and 1/4 inch thick. Even has the right size hole in the middle of it.
PERFECT for what you need. :wink:
PostPosted: Sat Sep 29, 2007 4:42 pm
The spindle I have the disc is 1/8" thick :evil: but there is TWO of them :D
David L
PostPosted: Sat Sep 29, 2007 4:57 pm
Tou want some foam with body in there, not that soft CD crap.... it'll just soak up water, if it doesn't shrink and fall out... :lol:
PostPosted: Sat Sep 29, 2007 5:49 pm
The stuff in my CD spindle looks and feels like neoprene - like wet suit material - won't soak up anything :wink:
David L
