It is currently Thu Aug 21, 2025 3:48 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 30, 2007 11:30 pm
maybe have a look in the rear arches and see if theres been any rubbing on the shock absorbers
PostPosted: Sun Sep 30, 2007 11:32 pm
My Cooper S made the exact same sound even on the straights, it turned out to be a worn hub bearing
PostPosted: Mon Oct 01, 2007 12:50 am
im with cookies dad, sounds to me like a shocker squeak, and if hes cornering fast on bumps it will go squeek squeek squeek
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Oct 01, 2007 8:14 am
Mine made squeaky noises on corners or uneven road surfaces.
Turned out it was the LH rear companion box `oil canning' ie. doing a `woop-woop' Rolf Harris wobble board impersonation.
A block of wood and juducious use of a BFH fixed it. 8)
PostPosted: Mon Oct 01, 2007 10:24 am
It seems fine when driving straight at any speed, I drove on the expressway and it pulled 120 nicely :D anyway thats beside the point. Yeah it could be the shockers...I used to have similar sounds even when driving straight and i thought it was a bent speedo or something, turns out it was the shockers and my dad made new bushes for them...so that could be the same problem when turning
PostPosted: Tue Oct 09, 2007 5:53 pm
Im pretty sure i know what the problem is, The drum brakes are scratching against the backplate.....Ill look into it on the weekend, it will be fairly easy to fix as i will be able to see metal scratch marks where its rubbing against (if that is the problem)
