It is currently Fri Jul 18, 2025 11:13 pm
PostPosted: Tue Jan 04, 2005 10:47 am
G'day again all
Well The yellow beast has been running like crap for the last week... anything over 4000RPM and 4Psi Boost was leaving me with the popping farts and misfires....
SO, yesterday i changed....
Plugs (From NGK BP7ES to Equivalent Champions)
Leads
Cap
Rotor
Condensor
Points
Now, i set the points gap (by eye.. nasty, i know but i was in a hurry...) to about 0.035"
at the PEAK of the dizzy cam....
It started first go, was a bit lazy to rev until it sat for a few mins (normal) then coughed and spluttered with a very low idle and almos NO bottom (below 1300RPM) torque.. almost couldnt get out of the driveway!
Once moving its clean, revs sweetly all the way to 7500 and will hold 12Psi boost without a hassle.....
SO, can points gap really make that much difference ?
Should i
a) open them a little
b) CLose them a little
c) Buy a Dwell meter you lazy, tightfisted git
d) leave it alone, its ok like that.
Cheers all
J
PostPosted: Tue Jan 04, 2005 11:12 am
C along with a set of feeler guages.
Aaron
PostPosted: Tue Jan 04, 2005 11:24 am
re reading your post, i wonder if your dissy is ok? Will be interested to see how it runs next time your start it, as if it is different again i would guess the advance has decided to wander off and do it's own thing. I would think that to be the worst case senario. How much dissy work do they do when you throw it on the dino?
Aaron
PostPosted: Tue Jan 04, 2005 11:59 am
(E) get rid of the points dizzy and fit a Pulsar dizzy.
Seriously sorry I'm no help at all Kazjim.
PostPosted: Tue Jan 04, 2005 12:28 pm
Well, I HAD one coming but Gareth ****ed off to the UK without finishing my Honda Brakes OR pulsar Dizzy ....
Yea, I'm not real happy about the way THAT turned out......
Anyone heard from him ?
J
PostPosted: Tue Jan 04, 2005 2:04 pm
Yes well I was waiting on the Honda brakes too from Gareth. Bummer
PostPosted: Tue Jan 04, 2005 2:32 pm
Hope you hadnt paid yet ......
I had swapped him a large amount of stuff ........
Now to either get it back OR the completed jobs within 30 days.....
Hmmm you reckon i have a chance ?
J
PostPosted: Tue Jan 04, 2005 4:14 pm
who is Gareth???
Is he in uk on holiday or living?
Let me know if you need some muscle power :twisted:
1974 Moke - 998cc
PostPosted: Tue Jan 04, 2005 6:02 pm
kazjim wrote:
...but Gareth ****ed off to the UK...
Heyy whoa. Don't swear like that when aaron's around. I've been flamed already.
PostPosted: Tue Jan 04, 2005 6:14 pm
i still think your a fool big willy but yes, i do believe that swearing doesn't need to appear of forums, it is simple, youngens get on here, and we should have enough of a grasp of the english language not to need to use the words. I must be a crusty old man, eh willy? All i do is pick on you, eh willy?
PostPosted: Tue Jan 04, 2005 6:18 pm
Yea, i apologise for that, but in this case it was justified.....
Probably $650 Worth of stuff left my garage with only a promise "yea, I'll get that to you"
"I'll need it by Christmas"
"Yea, no problem"
Then i tried to get in touch with him, only to be told he's leaving for the UK in the next few days !!
He Dropped the unfinished Disks to Kev's place (where they wait patiently - Im not rushing Kev, he needs the time to get that red beast ready to beat me at the Dyno day .....)
No sign of the Dizzy, or an apology, or even a possible return date....
So Sorry for the swearing, but in this case it WAS justified......
J
PostPosted: Tue Jan 04, 2005 6:35 pm
J
Spoke to him today, he's back in Oz, yes he has a dizzy for you. :wink:
PostPosted: Tue Jan 04, 2005 9:16 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
see if the shaft bearings are worn you know movement in the shaft i had this on a mini and it drove me to drink (well more than normal ok)
i rebuilt carby's replaced points cap leads condensor coil everything any ways finaly looked into the big stash and pulled out another dissy when i pulled out the old one there was lash in the bottom bearing ....
also is it mech advance the springs go off ya know
makka
PostPosted: Tue Jan 04, 2005 10:16 pm
kazjim, in the meantime, .035" is way too big a points gap. You would have bugger all dwell and they are more likely to bounce.. :cry:
Try .015" or so.
PostPosted: Wed Jan 05, 2005 8:12 am
0.015" is only a rough guide.
measuring points gap means nothing.
dwell is the only thing that matters.... 60 degrees.(51 for emissions)
use a dwell guage to be 100 percent correct.
Miniworx Centre 0883741299
Online BMW Mini Shop
