It is currently Fri Jul 18, 2025 10:55 pm
PostPosted: Tue Jan 04, 2005 3:50 pm
Ive unbolted her, and taken of the connection at the bundy pipe connection but the bloody cable wont come out!!!.
Do i pull it out through the bundy tube or should it simply come out through the motor?
Im guessing ive missed something again :lol:
[Maverick] 1971 Mini K
PostPosted: Tue Jan 04, 2005 4:04 pm
I'm with you a just left it for the last 4 weeks :?
PostPosted: Tue Jan 04, 2005 4:06 pm
I want mine out tonight though :lol:
Then I can mount him on the rotisserie 8)
PostPosted: Tue Jan 04, 2005 4:19 pm
undo the 4 screws holding the motor cover on and the cable will come out.
1974 Moke - 998cc
PostPosted: Tue Jan 04, 2005 5:00 pm
as 13 sec said, you have to take the cover off and remove the cable from the pin that holds it to the motor. Tricks of the trade! Haha
Aaron
PostPosted: Tue Jan 04, 2005 5:53 pm
Bloody oath.... :lol:
Thanks fellas....i managed to mount it anyway. Just gotta disconnect the cable tomorrow :wink:
PostPosted: Tue Jan 04, 2005 6:45 pm
Hi, jack......
Barney has the early wiper rack and wheel boxes, but a 2 speed Clubbie motor in there..
It wipes fine but the wipers do 180* right across the screen. :shock:
Can the later wheel boxes be fitted to an early car, so they wipe properly?
Anyone done it? :?
/Hi, jack :wink:
PostPosted: Tue Jan 04, 2005 8:06 pm
Hi, jack......
Anyone done it? :?
/Hi, jack :wink:
Oi :lol:
PostPosted: Tue Jan 04, 2005 9:10 pm
You don't ese that every day.
PostPosted: Tue Jan 04, 2005 9:14 pm
only way to fix it kev is to use the wheel boxes from a clubby. You may also need to use the inner thingy(can't think of the word) to make it right gear ratio.
Aaron
PostPosted: Tue Jan 04, 2005 10:23 pm
Aaron
Thanks Aaron,
The whole motor & box is a Clubby one, crank and all.
I have a full Clubby wiper setup spare, need to find an old 850 or Deluxe one so I can sort out these mods before I actually fit them.
:idea: I'll trawl thru kazjim's stuff on the 23rd! :lol:
PostPosted: Wed Jan 05, 2005 10:01 am
Aaron
Thanks Aaron,
good on you Doc - you can tell me how to set it up - my engineer says I've gotta have 2 speed wipers, I was thinking I'd need to drill holes in the wiper panel to fit the whole clubman assembly when I do it on the van ...
