It is currently Tue Aug 12, 2025 1:24 pm
 Post subject: Info about my Mini
PostPosted: Wed Oct 10, 2007 12:21 pm
Im only new to this and would like to know the best way in fixing up y beast.
I need new wheels and i thought that i may as well upgrade them.
Just wanted to know the stud pattern and offset of a 1974 clubman and wat the maximum size wheels that people have put on. Is it possible to fit 13's?
I will need my current wheels to be identifed if i were to replace the damaged ones. Ill try organise some pics asap.
danny
2 Door STi + 1926 Chevrolet + a 1974 Mini = 1 very wierd collection
PostPosted: Wed Oct 10, 2007 12:35 pm
Mini stud pettern is 4 inch PCD.
13" wheels will fit, but tyres can be tricky.
Brickworx has some I know that.
I wouldn't run 13" wheels if you still have the drums on the front.
Stay with 12's or 10's if thats the case.
:D
PostPosted: Wed Oct 10, 2007 12:41 pm
cheers. So 12's is it.
so PCD is 4 x 4 inch. Where can u buy 12inch wheels with that stud pattern? and do 12 inch tyres come in low profile??
PostPosted: Wed Oct 10, 2007 12:47 pm
I'm sure a local will point you in the right direction, but 12 & 13 inch wheels are fairly common amongst minis now.
Even try your local tyre dealer.
A 12" performance superlight can be had for $170 per rim or cheaper, but don't know what the go is with 12" tyres at the moment (stock wise).
:D
PostPosted: Wed Oct 10, 2007 1:59 pm
My wheels which you see below are 12's with low profile, 13's would not be practicle for anything other than show without major alterations to wheel arches and suspension. even my 12's scrub out now and then.
Daniel the concreter (for now)
1974 mini 1100, fully sick rims, disk brakes, new paint, air conditioning, cruise control,v-tech... wishful thinking
PostPosted: Wed Oct 10, 2007 3:39 pm
The Arch mods are offset dependent.
My 13" Performance wheels require no cutting of the bodywork, whereas a 7" wide rim will need upto 2 inches cut.
No real 'mods' are needed for the suspension, as long as it is all in top condition, and kept that way. Some harder shockers couldn't hurt of course.
:D
PostPosted: Wed Oct 10, 2007 4:30 pm
:D
I have 12" Superlight, they look great. Only problem is tyre choice in 12". AS far as i know it's either Falken or Sime/simex, not realy performance tyre.
