It is currently Fri Jul 18, 2025 4:18 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jan 01, 2005 6:19 pm
Happy new year :P .. Its easier to type that than it is to say it LMAO, i nearly lost my voice today, too much shouting in Surfers and Broadbeach last night :? ..
heres one of the one thats still in there.
PostPosted: Sat Jan 01, 2005 6:27 pm
Heres the ones at the other end. believe it or not the boot looks way better now than it did.. Dad took out 2 birdsnests and ratsnest (as if I'd touch that) :lol:
PostPosted: Sat Jan 01, 2005 7:24 pm
that big bolt isn't meant to be there - looks like it's been put in to clear a fat spare wheel, my blue cooper's brackets had been remade in gal to clear the spare contessa... my gold Cooper has the correct little rubber thingy - the center one has a rubber similar to the one for the bonnet prop, it's to grip a U shaped bar screwed to the boot board, to hold it down - mine is missing the bar
PostPosted: Sat Jan 01, 2005 8:30 pm
:D Dani and Dad... thats what I call great help..!! Now leaves me with something to think about. CHEERS
PostPosted: Sat Jan 01, 2005 9:02 pm
Are those brackets supposed to be pop rivetted, like in pic? I thought they were spot welded.. :? (it's been 20 years since I owned an S though!)
PostPosted: Sat Jan 01, 2005 9:09 pm
meant to be rivetted doc - something of an afterthought I reckon ;)
it's a bit funny that the extra tank base and the tabs for the tank breather are spotted but the brackets aren't....
PostPosted: Tue Jan 04, 2005 7:04 am
none are screwed. they are pop riveted
PostPosted: Tue Jan 04, 2005 9:19 pm
Here are some pictures of the boot board and brackets.
Here is the boot board.
This is the bracket under it to clip it into place.
and again.
This is the bracket and rubber that the board clips into.
There are two of these brackets for the rear of the board to sit on, they are supposed to have a rubber on top.
Thanks to ImageShack for Free Image Hosting
PostPosted: Tue Jan 04, 2005 10:21 pm
so its supposed to have a clip one, and two stands??? if so mine are modifiedto make the board higher as skgnns said .. yes i just looked it up in the mini spares book the middle one
has the clipand the outer 2 have partALH1473rubber buffer,bracket to boot board..
funny even the rivits have a mini part number...
the rubber clipthey forgot to number but its part2H9215
and the catch bracket fitted to boot board is part 14A9783
how clever is that :lol:
PostPosted: Wed Jan 05, 2005 10:36 am
Dani I could kiss you, but you're too far away, too young and your dad would probably belt me, oh, and my wife would belt me too - but the sentiment is there, now, where in Australia can I order one?
PostPosted: Wed Jan 05, 2005 7:52 pm
see this is the information and help you dont get in books...
well without effort. Good on you Dani.. I have written the parts down now and will be getting some myself...
PostPosted: Fri Jan 07, 2005 8:51 am
That Sounds good I will have to get some parts on order for when I do mine up.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Jan 07, 2005 7:03 pm
Here is the rest of the patr numbers from the Mini Spares centre book.
the 2 outside stands are
14A9781 support bracket LH & RH rear boot board support.
the middle one is
14A9782 support bracketcentre rear boot support
the splitpin that holds the 2H9215 rubbercatch on in ic PS610241L. dad has a tin full of mixed pins must be a few that fit in there i bet they want too much for that special pin LMAO.
at the other side by the seat there is 2x 14A9780 support bracket front of boot board..
i dont know if they have them , but their adress is 80 gibson ave padstow nsw 2211
virtual kisses are good LOL
PostPosted: Fri Jan 07, 2005 7:07 pm
aka Mini Car Clinic.. (Padstow Pirates..) :wink: 8)
