It is currently Fri Jul 18, 2025 10:53 pm
 Post subject: Died in the rain
PostPosted: Tue Jan 04, 2005 10:07 pm
Hey All,
My mate came over tonight and wanted to go for a ride in my mini for the first time. So we get in the car and head down to get a pizza for dinner and it starts POURING down. Could only see 20m in front of me, but the mini seemed to love it. Anyways about 50m from the pizza shop at a round-a-bout i hit a bump and the car suddenly died. OMG i couldnt start it, lost all electrics. Anyways my mate and I get out in the pouring rain and push the car 50m into a nearby servo. After 15 minutes of fiddly around I go and buy some WD40 and try that out .... but still no electrics. Anyways after alot more fiddling around I finally realised that my cut of switch had short out somehow when i went over the bump, so I cut the wires and by-passed the switch and my little mini started straight away. I was sooooooooooooooo relieved. Wet but relieved.
CYa
Lucas
PostPosted: Tue Jan 04, 2005 10:10 pm
minis stopping in the rain is a myth i reckon. only ever did it to me once, and that was absoulute torrential stuff. every 3rd car in the car park at the SFS was stuffed, so i did not feel to bad.
PostPosted: Tue Jan 04, 2005 10:14 pm
"Another great bush survival story from our fellow Aussie friend" -Russell Coight
And yep, it is a myth. It's only ever happened to me once too, and that was going thru a HUGE deep puddle (more like lake) whilst it was pissing down... and even then it was only a mere stutter.
PostPosted: Tue Jan 04, 2005 10:21 pm
Yea, I've driven mine through a foot of water no probs :shock:
3 time to the wife and Morris. yep Pulsar is on :lol:
I was waiting for the dizzy story tonight :arrow:
PostPosted: Tue Jan 04, 2005 10:25 pm
If a Minis ignition system is in good condition and clean it should not muck up but when the plugs get worn and the leads are covered in dirt the car can stop in a little drizzle.
So keep it clean and maintained and it should not give any trouble.
I run a plastic ice cream tub over my dizzy if I know it is going to be very wet, just to make sure!
 Post subject: Re: Died in the rain
PostPosted: Tue Jan 04, 2005 11:15 pm
mini_magic_au wrote:
Hey All
hey Lucas
lost all electrics. ... but still no electrics. I cut the wires and by-passed the switch and my little mini started straight away
Lucas... electrics...
isnt that a funny combination
CYa
cya mate
Inconspicuously Conspicuous
PostPosted: Tue Jan 04, 2005 11:17 pm
by the way, which wires were cut by the bump? and did you have 10m of wire spare in the boot? :shock:
nuclear mini's webber touches the firewall, and the wires from the dash crawl out through the rotary hole
every vibration is a step towards cutting them all off...
PostPosted: Tue Jan 04, 2005 11:27 pm
That can not be good :? I'd be extending them and feeding them a lot higher then :idea: Specaily with a Weber on it
PostPosted: Tue Jan 04, 2005 11:40 pm
the yellow mini we used to have would play up in the rain quite a bit. we eventually replaced the dist. cap, and it helped a lot, but something about that car was never 100% happy in wet weather.
the other minis we've had have never really had a problem. the red one had a rubber boot off memory.
PostPosted: Tue Jan 04, 2005 11:45 pm
I also used a rubber glove with the fingers tips cut off..had no troubles after that :D
PostPosted: Wed Jan 05, 2005 2:43 am
yeah well i am happy to say i saw no less then five other vehicles broken down at the same time as me hahahhaa and mine started as soon as i got rid of the vut out switch. all i did was cut the wires on each side of the switch then connect them together.
Plus the rain was torential
anyways she runs great now
Cya
Lucas
PostPosted: Wed Jan 05, 2005 7:01 am
Get some tape around the join mate :wink:
PostPosted: Wed Jan 05, 2005 10:37 am
I DID!
Users browsing this forum: No registered users and 69 guests
