I GRIT blasted the floor in Anton & Co's 850.
Found lotsa little holes, so welded 2 new front pans in.
The blaster I used came from work- a `Cadillac' unit, similar to a VacuBlast. Your compressed air fires the blast media at the panel and a built in vacuum system recovers it back to the shot tank and separates it.
What I wanted to say here is my 2.5HP, 50L belt drive compressor was
barely adequate. Proper blasting takes LOTS of air.
IMO sand or steel grit is fine for floors and inside the boot, but no way I would do exterior panels.
Watch out when you're finished- a bit of moisture and it'll rust while you watch. Spray something on it- WD40 or whatever.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
