It is currently Sun Jul 27, 2025 8:53 pm
PostPosted: Tue Oct 16, 2007 10:09 pm
This space for rent
BTW oxygen doesn't explode, it's not flammable in itself.
How does that explain oxygen fires at hospitals, or the Apollo spacecraft accident?
PostPosted: Tue Oct 16, 2007 10:14 pm
its doesnt explode but it accelerates a fire. Just like when you blow on an open fire.
No oxygen - no fire, no matter how much fuel you introduce, add more oxygen and you get a bigger bang. Afterall fire is ust oxidation of the combustable material.
PostPosted: Tue Oct 16, 2007 10:49 pm
OTOH acetylene is pretty dangerous stuff- it has a very wide fuel air ratio ignition range. Also, free acetylene is unstable above about 15 psi. This is why it is dissolved in acetone, in acetylene cylinders.
Holy Cow, now you tell me. We used to muck around with acetylene when kids, with our chemistry sets - calcium carbide & water. And also asbestos. Probably lucky to be alive :lol:
PostPosted: Tue Oct 16, 2007 11:06 pm
Pure oxygen can cause some fuels to spontaneously combust. Back in 5th form chemistry we were shown what a jet of oxygen on a newspaper would do - pretty spectacular :shock:
David L
PostPosted: Wed Oct 17, 2007 5:28 am
Matt, any chance of a pic/drawing? I didn't get that description.... :oops:
PostPosted: Wed Oct 17, 2007 6:15 am
MIG/MAG (pistol trigger-gas-arc-continous coil of filler wire)was primarily developed during WW2 for the ease of application of a filler material to join two parent materials,
During war-time, majority of the blokes were fighting whilce a very large contingent of female voluteers were tasked with building aircraft, vehicles and arms.
It was developed to speed production as well as to assist "a less skilled" cross section of society in the fabrication of steel/aluminium structures.
As I remember it, being to taught to me during my Polytech days.......
If you idiot proof the world, only idiots there shall be!!!!!
PostPosted: Wed Oct 17, 2007 10:14 am
Strictly speaking it doesn't have to be oxygen, there are other oxidisers that will support combustion in the absence of oxygen, chlorine, nitrous oxide etc.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Oct 17, 2007 10:15 am
This what you mean Matt - but not full welds around the tops of the towers?
David L
PostPosted: Wed Oct 17, 2007 11:39 am
Ditto :D
Am interested in the bracing for the towers and the diagonal bracing also, any chance of a pic or modifying the pic posted by Wombat??
PostPosted: Wed Oct 17, 2007 2:36 pm
This is my seam welded frame with thanks from Dr Mini:
PostPosted: Wed Oct 17, 2007 5:12 pm
I've thought of welding a piece of box section inside the front crossmember 1x1 inch (and also the same on the rear frame 2x2 inch). Would this give these areas enough strength to become jack points? :?
This pic gives the idea but they would span the whole length, left to right.
PostPosted: Wed Oct 17, 2007 5:41 pm
Timbo wrote:
Strictly speaking it doesn't have to be oxygen, ... , nitrous oxide
you know that nitrous oxide contains 33% oxygen? with heat it will break up into 2 nitrogen and 1 oxygen part, thats why you can use it to burn more fuel in an engine.
Rover 214 atm ....
