It is currently Fri Jul 25, 2025 11:54 pm
 Post subject: generator brushes
PostPosted: Wed Oct 17, 2007 8:22 am
One of my dash lights comes on when I rev the engine up (not ignition or oil)< so I assume it has something to do with the generator, can also see big sparks inside it when you rev it up. Does this mean I need to change the brushes, and if so how hard is this to do? Thanks Steve.
PostPosted: Wed Oct 17, 2007 10:26 am
Hi Steve,
It is not a difficult job for an auto-sparky but probably something a little much for someone without skills in such matters. If the brushes are worn to the extent it is affecting the output, then you can pretty much guarantee the bushes and commutator will need attention too. See if you can find an "old school" auto electrical place near you, they should know these old Lucas generators backwards.
Regards
Al
PostPosted: Wed Oct 17, 2007 3:10 pm
Also, check the bronze bush in the end plate as these are prone to wear :wink:
Users browsing this forum: Bing [Bot] and 110 guests
