It is currently Wed Jul 30, 2025 12:00 am
 Post subject: camshaft specs
PostPosted: Mon Oct 22, 2007 4:32 pm
does anyone have specs for camshaft grinds to suit a healthy 1293 (say maybe an "R.E. 15" spec for example, etc, etc as would like to compare a few prior to getting mine done.) 8)
PostPosted: Mon Oct 22, 2007 4:41 pm
By "healthy" you mean big jugs & valves, worked over head?
I've always been a fan of the factory grinds, AEG510 (std S cam), AEG731 but no doubt times have moved on............. :wink:
PostPosted: Mon Oct 22, 2007 7:17 pm
Here's specs on a few including the RE13...
http://www.mlmotorsport.com/forum/index.php?topic=11.0
PostPosted: Mon Oct 22, 2007 9:34 pm
:D Thank you very much Drmini and AEG163 your info has been very helpful :D
PostPosted: Mon Oct 22, 2007 9:47 pm
also http://www.wadecams.com/
and click 'popular cams'
then 'BMC A series'
446b looks pretty good!
Noli Illegitimi Carborundum
PostPosted: Mon Oct 22, 2007 9:54 pm
then 'BMC A series'
We have a Wade 104 (or Tighe 104, same thing) in Barney with 1.46 rockers. It's a good roady cam but doesn't have the midrange of an RE13. :wink:
PostPosted: Sat Oct 27, 2007 1:53 pm
:twisted: :lol: have decided on a camshaft for "BLISTC" its gunna be a very similar spec to the "wade 176" grind.......mild mannered up to about 3,500 rpm and an animal from 3,500 to 6,500-7,000 rpm!! its gunna be a very good combo!! :lol: :twisted:
gunna see how it goes with the steel rocker gear(1.3's), then maybe try the toyota rockers later once it has a few miles under its belt (so to speak).
To use vernier timing gears, or use cooper s timing gears that is the question?? hmmmmm......what to do, what to do........i know the bloke who grinds these cams is normally very spot on (when used with std double row timing gears) but they have been much milder grind cams and we have never had a problem with them. Might stick to the cooper s timing gears i think.
PostPosted: Sat Oct 27, 2007 4:23 pm
I'd use Cooper S duplex sprockets if not worn, and an Iwis (german made) chain, they are the best. ($60 or so).
I use offset cam keys to get them spot on, never had a problem.
If the sprockets are worn, I'd go buy a Rollmaster kit, they include the Iwis chain and vernier keyways for $150 approx.
PostPosted: Sat Oct 27, 2007 4:36 pm
:D the sprockets are in really really good condition!! my mate has some off set cam keys IF they are required. will see how we go when it is all machined etc and ready for assembly!! 8)
PostPosted: Sat Oct 27, 2007 5:01 pm
Assemble with a standard key, then see how far out it is.
Ask Wade what it should be timed at with a chain. :wink:
When finished, Loctite the nut with some 262, and tighten to 75 lb/ft. Will never come loose. 8)
Users browsing this forum: No registered users and 129 guests
