It is currently Sat Jul 26, 2025 5:51 pm
 Post subject: Badges
PostPosted: Fri Oct 26, 2007 8:41 am
Simple question... whats the best (ie. and easiest) way to attach original metal badges to a car...?? The badges still have the "sticks" off the back, so is it just a matter of pushing these through the holes in the boot and bonnet and then soldering some solder around the back..??
PostPosted: Fri Oct 26, 2007 8:47 am
Mouse condoms, special little plastic plugs that are intended for holding badges on. You can get them from business that supply parts for bodyworks.
Or do a search on here for "mouse condoms".
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Just get some of the mouse condom nylon badge doovers from a mini place and slip them over the posts before putting the badges on , they compress to fit through the holes and swell slightly again to hold them in . If you are looking for something stronger again talk to a panel shop about the tape they use to fix them to modern cars and use a little of that as well .
PostPosted: Fri Oct 26, 2007 10:43 am
I have found clear silicone to be the best adhesive for badges. It is flexible so takes the vibration really well. I would stick the mouse condoms on as well though, doesn't hurt to have extra safety.
Pete
PostPosted: Fri Oct 26, 2007 11:24 am
so how do you stop someone just giving your badge a pull and it coming off..?
PostPosted: Fri Oct 26, 2007 12:00 pm
You can also buy metal lugs from auto shops, i know robbos have them ...
but you need to get to the back of the badges to attach them ...very strong and GREAT for grills...
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Fri Oct 26, 2007 12:03 pm
Iwannamini, if someone was to try and debadge my car I'd rather it come out a little more easily than them ripping a hole in the front of my car. Because either way if they want it they will take it, even if its bolted in.
Talk is Cheap because Supply Exceeds Demand
mattsmadmini wrote:
you've got awesome norbles
PostPosted: Fri Oct 26, 2007 12:11 pm
Get the tape I mentioned , I can't remember the name but it's a black spongish looking stuff a couple of mm thick . Ask at a panel beaters and they'll know what it is . Aslo , the mouse condoms hold them on fairly tight anyway .
Are they normal badges you're putting on or something special , if normal just have a few spares as backup as well .
PostPosted: Fri Oct 26, 2007 12:17 pm
VERY good point. Little condoms it is....
Thanks...!
PostPosted: Fri Oct 26, 2007 12:41 pm
You can't.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Fri Oct 26, 2007 1:02 pm
Give Ash some flowers Nick .
The tape I use on my car (super sticky and the stuff I think sports is talking about) is 3M Body Moulding Tape. It comes in a red and black packet (well it did the last roll I bought).
<edit> here is a pic:
Can't find a pic of the box it comes in.
PostPosted: Fri Oct 26, 2007 6:10 pm
You can get little round circlip type things that squeexe onto the pins at the back. They are high tensile and hard to move once they are on
Crazy Minimad
PostPosted: Fri Oct 26, 2007 8:43 pm
To stop the mouse condoms splitting, soak them in hot water before pushing them into the holes.
THEN push the badge in. :wink:
PostPosted: Sat Oct 27, 2007 1:04 am
circlip things that slip on teh back, and urethane :wink:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Oct 27, 2007 1:42 am
Condom's are the way to go.
I used the metal circlips as well along with this black bluetack/sikaflex type stuff that my panel beater gave me. Much stronger hold, but easy to remove if you have access behind and they don't crack like the condoms do with age.
