It is currently Thu Jul 31, 2025 8:54 am
PostPosted: Fri Oct 26, 2007 9:17 am
Hey all just wondering the advantages and disadvantages?
thanks,
- tom
PostPosted: Fri Oct 26, 2007 9:58 am
The only head gasket to use is the single torgue type that is used for A+ turbo type engines.
Karcraft has them for both small bore and big bore engine (they are slightly different)
Mike
PostPosted: Fri Oct 26, 2007 10:03 am
awesome thanks mike!
i saw the monotorque gaskets around!
ill grab one of those then!
im running a 12g295 head on a 998 block with 1100 crank rods etc.. so id get the 998 gasket?
cheers,
- tom
PostPosted: Fri Oct 26, 2007 10:17 am
Yes - use the gasket appropriate for your engine - yours is a small bore and even if it was bored out it would still be a small bore.
Big bore engines (1275 and those bored to above) are a different casting and have a few things (such as water holes) in slightly different places. Also the spacing between the cylinders is different.
So the small bore (850, 998, 1100) single torque turbo type gasket is the one for you.
Mike
PostPosted: Fri Oct 26, 2007 10:20 am
awesome thanks very much mike!
i picked up this but not off ebay (got it cheaper elsewhere)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=300164200745&ssPageName=STRK:MEWN:IT&ih=020
PostPosted: Fri Oct 26, 2007 10:31 am
Yes - that should be fine
With the 295 head have you had it shaved for the bigger combustion chambers it has or using flat top pistons ???????
If not you going to have a pretty low compression ratio so the gasket will cope easily.
Mike
PostPosted: Fri Oct 26, 2007 10:36 am
havent put the head on yet... still running the head that came with the car which is running fine.. getting the head ported and polished etc in the next week or 2...
anything to ask for when eddie's doing it?
PostPosted: Fri Oct 26, 2007 10:53 am
Okay plenty of detailed threads on here about the 295 heads and what is needed to make the mini have the right compression.
DrMini has given pretty explicit directions about how to measure what has been taken of the head already and hw much to take off it more is necessary.
Search for those - its very helpful
Mike
PostPosted: Fri Oct 26, 2007 11:12 am
I have a 295 head waiting to go on my 1100 rebuild - I don't want to shave the head to I've been waitng for GRs flat top pistons. It came with unleaded inserts, I had slightly larger exhaust valves fitted and new double valve springs, guides and a skim flat and cracked tested. Also fitted a new brass bypass (per the Doc's design ) cleaned out all the threads fitted a new temp sender and have new studs all round> Gave it a coat of black epoxy but now have changed my mind on engine colour and will repaint it when the engine is all together
David L
Users browsing this forum: Bing [Bot] and 84 guests
