It is currently Wed Jul 23, 2025 12:26 pm
 Post subject: Fitting flares
PostPosted: Sat Oct 27, 2007 5:36 pm
Hi all,
I have a question regarding fitting flares. I need to fit some screw on flares to cater for the 10 x 5 inch wheels (not sure how the previous owner got passed rego).
I have the black plastic screw on types. I have the screws which will secure them.
Any ideas on the best method to install these?
Thinking of drilling the required holes, painting around the holes to try and protect against rust and then screwing in... but would the screws simply scrape the paint away within the newly drilled hole? Just very mindful of giving a starting point for rust.
PostPosted: Sat Oct 27, 2007 5:50 pm
you have'nt got much choice, I reckon drill a piolt hole and paint it like you said. Their is a lot of minis getting around with those flairs on em and I have'nt seen any with rust on the flairs.
PostPosted: Sat Oct 27, 2007 5:52 pm
if you don't want to drill into the panels, you can drill up under the part of the arch that sticks out from the fender...
then rivet or screw the flare to that... i'll hold nicely and you won't have to bog it up if you want to fit different wheels..
like i did.. ;)
PostPosted: Sat Oct 27, 2007 6:38 pm
Throw away the little black screws, they will rust the 1st time it rains. :evil:
Go to Bias Boating Warehouse or Whitworth's, take a screw with you and buy some S/S ones the same size. 8)
I drilled the holes, put a dab of grease on the screws and screwed them in. No body rust there in the last 10 years. :wink:
PostPosted: Sat Oct 27, 2007 7:15 pm
on the car, at least.. ;)
PostPosted: Sat Oct 27, 2007 7:26 pm
the operative word is there..... :lol:
 Post subject: Flairs
PostPosted: Sat Oct 27, 2007 9:51 pm
I put my flares on the same way.
Steve
Classic Not Plastic
PostPosted: Sun Oct 28, 2007 10:01 am
Thanks for the responses. Very glad i asked the question.
 Post subject: No rust flare fixing
PostPosted: Sun Oct 28, 2007 11:59 am
Rover Cooper
I done exactly what Doc said, except I dipped the screws on a tin of paint, that matched the car, screwed them in and hey presto, hole and screw matched the flare and the car colour, so now hopefully no rust in the future.
Davo...,
Users browsing this forum: Barkfast and 92 guests
