It is currently Sun Aug 17, 2025 12:44 pm
 Post subject: Volt Gauge
PostPosted: Sun Oct 28, 2007 3:46 pm
Just instaled a Speco Volt Gauge
It reads 12 Vots at idle
bounce between 12 -11 1/2 with Blinkers
and to 0 with the lights on
Is this normal but I'm guessing the Alternator is not charging enough
PostPosted: Sun Oct 28, 2007 3:50 pm
You've not got it wired properly then, it should be connected to the main battery cable at the solenoid, and a good earth on the body.
bring it over. :wink:
PostPosted: Sun Oct 28, 2007 3:56 pm
going by the paper work it showed to wire it the Acc and to an earth..taking the Binicall is a pian in the Asre :twisted:
I'll correct it :roll:
Can I hook it up to the Fuse box ( Constant power or (Not))
PostPosted: Sun Oct 28, 2007 5:42 pm
You want to know what the battery voltage is, not how bad your wiring is.
I wouldn't bother unless it's wired either off the battery cable at solenoid, or via separate wiring right back to the battery. Both these will read the same really.
PostPosted: Sun Oct 28, 2007 5:47 pm
We wired to Solenoid and to the body for the Earth.
Stoped the Bouncing Blinker..but Still 0 for Head lights
PostPosted: Sun Oct 28, 2007 5:49 pm
something wrong then
PostPosted: Sun Oct 28, 2007 5:50 pm
I'm not :shock:
This is why I was putting it in the first place
PostPosted: Sun Oct 28, 2007 6:07 pm
ausmini mod
ausmini mod
Your light wire to the speco guage is losing earth more than likely when the headlights come on.
How do I explain... ummm ...
undo the earth from the guage and tell me if it still does the same thing with headlights, or if it does nothing at all.
Pete.
PostPosted: Sun Oct 28, 2007 6:16 pm
the light for the gauge is seperate...similar to our binicals if you like
PostPosted: Sun Oct 28, 2007 9:06 pm
ausmini mod
ausmini mod
Yeah, I know that. I had EXACTLY the same problem with a speco guage.
Turns out I didnt have the speco guage earthed (not the earth FOR the guage) ... hard to explain... when I ran the wire and touched it on the chassis somewhere metal, the light worked.
I turned on lights, dropped to 0, turn off lights and the guage reads correctly, but no lights (obviously)
Found the earth loose and put it on.
Presto.
PostPosted: Sun Oct 28, 2007 9:07 pm
Cheers will check that again tomoz :wink:
PostPosted: Mon Oct 29, 2007 6:09 am
Jim, sounds like you have more voltage drops than you want to know about in your car... If you want to use the gauge permanently to read actual battery voltage. you will have to get the positive wire to it from your Starter solenoid battery side. But if you wire it direct and not switching it, when the car is turned of it will flatten your battery when car is parked for more than a day or so. My advice would be to wire it through a small relay switched by the ignition switch. Don't let the smoke out or it will never work then !
"Let us remove your "SHORTS"
PostPosted: Mon Oct 29, 2007 6:19 am
Yep I have it on the Starter solenoid with the earth to the body now. I'll actualy disconnect i to night or i'll check the earth (back of gauge) if i have the time tonight
PostPosted: Sat Nov 03, 2007 4:04 pm
rewired and checked again..no luck
PostPosted: Sat Nov 03, 2007 4:57 pm
Bring it to the surgery then. 8)
Users browsing this forum: No registered users and 304 guests
