It is currently Fri Jul 18, 2025 4:06 pm
PostPosted: Mon May 03, 2004 9:04 pm
hey guys, just wanna know if the mini morris and clubman flares are all the same....
ie if morris flares will fit onto clubmans and vica versa.
if not then can u modify them to fit ie sand back a few spots or is it worth just getting new ones that are right.
thanks..
PostPosted: Mon May 03, 2004 9:11 pm
If you mean the Oz MK2 flares I think they can be fitted to a Clubbie front with some mucking about. Rears are the same.
Check your Mini shop or email [email protected]
I've seen Innocenti plastic flares (like mine) put on a Clubbie too. No big deal.
PostPosted: Mon May 03, 2004 9:15 pm
Round nose front flares are definitely different to Clubman and will not fit. This refers to standard plastic type, not aftermarket or innocenti.
PostPosted: Mon May 03, 2004 11:21 pm
dnt know wat they are called but have a pic.
they are these ones guys...
please let me know....
thanks
PostPosted: Tue May 04, 2004 6:17 am
If those are screw holes I can just see, they are plastic `Innocenti' screw-ons. Can be put on a Clubbie but the fit around the front is not real good. Rear ones fit fine.
Designed for roundnoses.. :wink:
If your car has the metal strips in the guard lips already (Clubman Mini S?) these are not for you...
PostPosted: Tue May 04, 2004 8:43 am
yea I saw those on ebay and thought they were Innocenti type, then I thought maybe they were standard plastic type, but with some chips in them (ie: broken like most plastic type flares)
What you get is what you pay for. Go cheap, get cheap...... :wink:
EDIT:- I see some on ebay now for $50. If they are innocenti type, forget it. You can buy them new from Karcraft for $60.... :lol:
PostPosted: Tue May 04, 2004 11:57 am
oh ok...thanks guys.
prob just get them new.
:D
