68matic wrote:
hi
matic blew a head gasket
probably a good opportunity to see if the cooper head was nicked
1) would a head stamp of "12A 1456 SM"
or "12__1_6"
be characteristic of a matic head?
i was told matics came out with Small Cooper heads and "12G295" would be expected with larger valves by Doogie and Steve,
not sure what the one off mine's goin on about.
my block has the stud/washer/nut thing so people tell me its an english block
2) did matics come with metal universal joints, or rubber ones with metal U hooks, connecting the diff to the driveshafts?
thanks
Duc,
1.
'Matics (UK 850, and our 998) all had the 12A1456 head, with standard 998 valves. No 295's here..
They had 9:1 C/R, because the pistons had less dish. Also had HS4 carb before any others. All this added up to 3HP more than stock 998 Deluxe. Wow...
They all had studs, as all autos were English blocks.
Like the 1275 auto the oilways are funny- so won't go on a manual box without reworking.
2.
All had metal Hardy Spicer U/Js, same as Cooper S. No rubber joints.
I suggest you use a standard composition gasket, not the copper one. We've had some trouble with those lately.
Best gasket around for 998/1098 at the moment is the `ACL' one, IMO. Repco or AutoOne have it or can get.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
