It is currently Sat Jul 19, 2025 1:17 pm
How wonky is your wheelbase?
0mm - 4mm difference 0%  0%  [ 0 ]
5mm - 9mm difference 25%  25%  [ 1 ]
10mm - 14mm difference 25%  25%  [ 1 ]
15mm - 19mm difference 25%  25%  [ 1 ]
20mm+ difference 25%  25%  [ 1 ]
Total votes : 4
PostPosted: Sat Nov 03, 2007 6:48 pm
This space for rent
When I converted from drums to discs a month or two ago, I also installed a set of adjustable lower arms and caster/tie rods. With the caster arms at the original factory length, the wheelbase was identical on each side of the car, but it pulled hard to the left on the road.
I dialled that out by adjusting the caster on each side of the car, and now that's left me with the following wheelbase:
Left - 2037mm
Right - 2052mm
.. for a difference of 15mm side to side.
My brother's clubby is worse, it has a 20mm variance.. but it points straight as an arrow.
What's everyone else's?
PostPosted: Sat Nov 03, 2007 7:01 pm
I wouldn't get too excited by a difference, a Renault 16TS had one side 100mm longer, as the rear torsion bars were mounted behind each other.
To drive it, you would never know. :wink:
PostPosted: Sat Nov 03, 2007 7:03 pm
This space for rent
Yeah, I'm not worried about it at all.. I'm just curious how many straight Mini's there are out there :lol:
PostPosted: Sat Nov 03, 2007 7:14 pm
Well mine got shunted in the LR sometime in the past, I have a 5mm spacer on the RR hub to get wheel offset right. And it took some surgery on the trailing arm bracket to fix crabbing too. But it's fine since I did it. 8)
PostPosted: Sun Nov 04, 2007 4:37 am
I am unsure of the history of my mini, and I have never driven it. I didnt look like it had been pranged. BUT if i do get it going and its pulling or crabbing could I have a panel shop put it on the bench and give it a stretch for me ?
blokeinamoke wrote:
PostPosted: Sun Nov 04, 2007 8:48 am
It would be cheaper and easier for you to fit adjustable suspension all round. You can do height, front/rear camber and caster for very little (by comparison to any other car every made).
PostPosted: Sun Nov 04, 2007 9:07 am
so how to you measure it?
PostPosted: Sun Nov 04, 2007 9:22 am
This space for rent
Grab a tape measure and a helper, and with the steering dead straight, measure the distance between the same points on the front and rear wheels. I measured from the point where tyre meets rim.
