It is currently Wed Aug 06, 2025 10:32 pm
 Post subject: Info required
PostPosted: Tue Nov 06, 2007 8:34 am
can anyone tell me if this is the correct charcaol canister for a 1978 leyland mini s. And if it is do you know where the third tube goes to, i only know about the one to the petrol tank and the big one to the rocker.
PostPosted: Tue Nov 06, 2007 8:48 am
High heel ninja
Yes it is the right one for your model, 3 ports on top, one to the tank, one to the rocker cover & possibly one to the crankcase breather on the right side on the rear of the engine.
Doogie
PostPosted: Tue Nov 06, 2007 9:03 am
No Doogie, on a `78 the crankcase breather goes to the vac port on the side of the HS4 carb.
the 3 hoses on canister go to-
fuel tank vent,
rocker cover,
float bowl vent on carby. :wink:
PostPosted: Tue Nov 06, 2007 9:08 am
High heel ninja
fuel tank vent,
rocker cover,
Thats right Doc, was gunna edit my post about a second after you posted, no need now
Doogie
PostPosted: Tue Nov 06, 2007 11:50 am
thanks for the info. i can put it in properly now
