It is currently Sun Jul 27, 2025 9:41 am
PostPosted: Wed Nov 07, 2007 5:25 pm
That yours?
If so, nice tyre choice. :wink: 8)
PostPosted: Thu Nov 08, 2007 5:09 am
Yep...I'm thinking I may also add some pistons and pads and hoses etc yet though :lol:
PostPosted: Thu Nov 08, 2007 5:57 am
how close does it get to the balancing weights on the rims?
i had a set of 4 pots that would take the samllest of weoights off and ended up playing with the tires turning them around to get them as close to balanced as possible.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Thu Nov 08, 2007 6:05 am
Yeah I had a small moment of panic about that myself - but the weights ended up toward the outside of rim (further in, looking at that pic), so nowhere near the calliper. Actually one didn't need any weight.
PostPosted: Thu Nov 08, 2007 6:40 am
Nice wheels stu :wink:
PostPosted: Thu Nov 08, 2007 12:20 pm
Nice rubber 8)
2008 Prado GXL
PostPosted: Thu Nov 08, 2007 1:09 pm
nice offset... :roll:
PostPosted: Thu Nov 08, 2007 3:35 pm
:lol:
 Post subject: Re: 10 Inch Mags
PostPosted: Thu Nov 08, 2007 6:49 pm
Booglie wrote:
I was just wondering if there are any 10 inch mags that will fit over 8.5 disks as i currently have 12's but want to go back to 10's
This guy in canada does a conversion to vented honda discs to suit 10inch wheels. http://joltfreak.tripod.com/id1.html Its a good website too.
His words:
The great thing about this kit is that you retain most of you mini parts.You will get the caliper mounting plates that enables you to mount the 1984 - 1987 Honda Civic calipers and brake pads (which you still need to buy on your own) to your existing drum braked mini's swivel hub and the Honda Civic rotors which i will provide with all the machine work done if you buy the full kit he machine work required for the rotors are :
Bore the centre of the disc out to 65.0mm diameter and Machine the disc down to 7.90" diameter and Re-drill the disc accurately to suit the Mini stud pattern.4 holes 10.0mm diameter on 4.0" (101.6mm) PCD). The only thing that you must do is knock the studs out of your existing drive flange. Set up true in lathe, machine the front of flange down to 65.0mm diameter. Only take a few thou off the front mounting face to clean up, where the drum sat and allow the rotor to sit true. You'll need to get cooper S studs which are longer and a 1inch spacers. all the things you'll need to get is:
1985 Honda Civic Calipers w/bolts & pads
1 inch spacers
two extra copper washers.
cooper S Studs
The offset is the same as a mini equipped with "S" brakes. The reason for the one inch spacer is to ensure that the caliper will not foul on the rim. The plates fit onto your existing spindle (were the backing plate from the drum brakes fit) if you wish to order the basic kit it will cost $300 Cdn. plus shipping the full kit will cost $500.00 Cdn.
plus shipping.
67 Deluxe under going full resto
PostPosted: Thu Nov 08, 2007 7:08 pm
This space for rent
Yep, that's right. 7.9" discs are the absolute maximum size which will fit within a 10" rim, and then only some rims at that. You need to leave some space between the rotor and the wheel for a caliper to squeeze into :lol:
