It is currently Sat Jul 26, 2025 11:49 am
 Post subject: radiators
PostPosted: Thu Nov 08, 2007 6:21 pm
are mini radiators inter changable. say one that fitted a clubbie. will the fit straight into a roundie...???? 3 core radiator..
just another. what sorts of radiators wont if some cant.
PostPosted: Thu Nov 08, 2007 6:54 pm
They will come across, but you will also need to bring across the thermostat and the top hose (which means maybe a couple of gaskets as well).
The inlet for the top hose varies from model to model, so this changes the angle of the thermostat housing and the length of the rubber hose. The rest is fine.
PostPosted: Thu Nov 08, 2007 7:31 pm
You may require a thinner spacer on the fan, they come in two sizes. I believe there have also been different lower shroud brackets too. But generally you'll be fine.
Users browsing this forum: stewartp and 90 guests
