It is currently Fri Jul 18, 2025 9:47 am
Post new topic Reply to topic  [ 305 posts ]  Go to page 1, 2, 3, 4, 5 ... 21  Next
PostPosted: Sat Nov 10, 2007 4:19 pm
well peter (pristic) was building his hot 1132 around the same time i finished my turbo conversion. when it originally went on the dyno he was impressed but still wanted a 8port as he wanted around the 140hp mark.
after changing a few things (see my thread http://www.ausmini.com/forums/viewtopic ... highlight= ) i managed to get 140 hp with mine , without the cost of a 8port head. Quikly peter was very interested and i convinced him to build an all out 998 turbo. The plan was 20psi boost plus the same turbo as me but over the clutch and an expected output of hopfully 160ish flywheel hp.
So peter organised the bits while i did his turbo setup ( manifold dump pipe and turbo fitings). Iv been doing it for a couple of months now in between other things.
Peter is now starting to get impatient and has dicided to swap cams in his 1132 and run the setup on that with low boost while he is building his 998.
anyway ill update things as there done :wink:
PostPosted: Sat Nov 10, 2007 4:30 pm
Looks good Ben!
Another conversion killer (ducks for cover)
Daniel
PostPosted: Sat Nov 10, 2007 4:34 pm
That's a nice neat looking setup , I'll be watching this thread to see how it all goes .
PostPosted: Sat Nov 10, 2007 4:39 pm
ausmini mod
ausmini mod
DOZ wrote:
Looks good Ben!
Daniel
Hahah, we'll see how she goes at the runs one night... but should be fun :D
PostPosted: Sat Nov 10, 2007 4:46 pm
More importantly what colour are you going to paint it? :P
Lillee - 1969 Morris Mini K
PostPosted: Sat Nov 10, 2007 4:47 pm
ausmini mod
ausmini mod
Pfft, she's a sleeper... ;) Wont know anything from the outside... hehe
Just like Ben... looks like a nice little mini...
Peter.
PostPosted: Sat Nov 10, 2007 5:37 pm
i love it, go the 998.
how much is the metro turbo stuff costing?
PostPosted: Sat Nov 10, 2007 5:46 pm
ausmini mod
ausmini mod
Like asking a lady how much she weighs!!! :shock:
Nah, im kidding.
Your looking at around $1000 to finish the job really.
It all adds up.
Turbo, Carby, Intake, Plenum, Blow off valve, pipes, oil return lines, regulator, electric fuel pump, bits and bobs here and there... Dont forget camshaft grind, head studs to handle it all (ARP), etc...
Pete.
PostPosted: Sat Nov 10, 2007 5:51 pm
Nah, im kidding.
It all adds up.
Pete.
i would probably do something like that, i have foot in mouth
running the re-13T yea?
PostPosted: Sat Nov 10, 2007 5:55 pm
ausmini mod
ausmini mod
Yep!
PostPosted: Sat Nov 10, 2007 7:33 pm
Where abouts did you get the metro turbo stuff?
Did you have to get it from the UK? or, is there somewhere here that sells that stuff?
Also do you reckon you'd be able to fit two turbo carbies side by side with plenum's?
PostPosted: Sat Nov 10, 2007 7:49 pm
i dont know what would be the point of running twin carbs on a turbo
PostPosted: Sat Nov 10, 2007 8:00 pm
The single SU as fitted to the Metro turbo would provide plenty of power but I can understand the idea of fitting one for each port - you might be onto something there....
Daniel
PostPosted: Sat Nov 10, 2007 8:15 pm
ausmini mod
ausmini mod
I got from the UK. I think it all comes from there.
Some people have the setup here and happy to sell... but VERY expensive
One is a tight fit, not sure how you would fit 2.
One on each port would be interesting, but hard to setup I would think.
Pete.
PostPosted: Sat Nov 10, 2007 8:21 pm
You didn't hear it from me but you can get metro stuff from NZ...
