It is currently Sun Aug 17, 2025 6:49 pm
 Post subject: Brake disk shields
PostPosted: Sun Nov 11, 2007 1:25 pm
Hi all.
Just getting around to overhauling a set of 8.4 discs & hubs I bought a while ago. Unfortunately, I have only one disk shield.
Do I need to source another one, or can they safely be deleted?
Thanks. Scotty.
:roll:
PostPosted: Sun Nov 11, 2007 1:29 pm
They're not really necessary , there is a very remote chance of getting a stone wedged between the caliper and the disc rotor but it's a very slim chance .
PostPosted: Sun Nov 11, 2007 2:08 pm
You are more likely to get a stone stuck in there if you leave them on. :lol:
They may be useful in UK where they salt the roads, here in Oz I reckon bin em. All they do is restrict disc cooling.
:wink:
PostPosted: Sun Nov 11, 2007 4:44 pm
my mini had 1 when i got it...now has none :)
PostPosted: Mon Nov 12, 2007 7:38 am
They're only held on by thin tabs that always break and then they rattle worse than anything else on a mini. Unfortunately they are a roadworthy item - so I now just keep a set at home to put on for such occasions.
Only disadvantage I've noticed when not running them is that you can get more water under the pads. After a drive along a wet freeway for a while I've found the first (non) brake application was a bit of a wake-up :shock: . I'm use to it know and have developed the habit of giving myself enough space to give the brakes a couple of quick dabs first to get the water film off the pad surface.
PostPosted: Mon Nov 12, 2007 7:47 am
I want to have Al's babies
:shock: Sounds like a good reason to leave them on to me. :?
My passenger one cracked on the joint and dad and i welded it back up (it rattled like a bitch). :lol:
Users browsing this forum: No registered users and 288 guests
